Old 11-03-2007, 12:54 PM   #1
Car: 04 obp gt30r sti
IWSTI Addict since: Jul 2007
Default Cusco Zero2r install question
Hi,
I've installed the front 2 coilovers, no problem. I want to know if there is anything I need to know to install the rear coilovers? The instructions are in japanese, so any advise or help would be appreciated. Thanks alot.
Tedstriker is offline   Reply With Quote
Old 11-03-2007, 12:58 PM   #2
IWSTI Addict since: Aug 2006
Trader Rating: (15)
Default Re: Cusco Zero2r install question
Nope.. Only thing I should warn you about is the strut top bolts. Their a PITA to get to easily, make sure you have time, or a pivoting box wrench. Just take you're time!
Old 11-03-2007, 02:05 PM   #3
Do I need to remove the rear seats? how do I get to the bolts?
Old 11-03-2007, 02:10 PM   #4
Car: 04 WRB STi
Fav Mod: JDM STi Recaros
IWSTI Addict since: Jun 2006
Yes you need to remove the rear seats, like 4 bolts and literally 1 minute is all it takes.
yakmasterjack is offline   Reply With Quote
Old 11-05-2007, 04:28 PM   #5
Car: 06 WRB STi
Fav Mod: Cusco Zero2R
Send a message via AIM to iamadam1122 Send a message via MSN to iamadam1122 Send a message via Yahoo to iamadam1122
yes, remove the rear seats. its not hard at all. and its pretty much the same deal as the fronts. the brake lines have a clip instead of a bolt tho.
iamadam1122 is offline   Reply With Quote
