| | #61 |
| Professional STI Racer
Car: 05 WRB STi Fav Mod: TiC AST's - 7/6K Location: Chesapeake, VA Posts: 624
IWSTI Addict since: Feb 2005 Trader Rating: (3) | As a quick experiment, I went out and measured the amount of compression on my tires. These are my winter tires and I have lowering springs, but it should be a ballpark number. I measured 1" of compression of the tire radius. That means the spring rate at this weight is around 900lbf/in. If anyone is out there running the stock tires, can you take some measurments and post up? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #62 |
| Junior STI Driver | yeah I was comparing your guys #'s on unsprung weight w/ the STi and they are close- as you point out there are places are where there are some savings, others that add- overall very close ![]() do you have the link for the article you ran across? I've been scouring this site to look for "clues" on the inclusion or exclusion of the swaybars- nothing yet (some interesting reading though on some other subjects )Automotive suspension engineering Forum - Eng-Tips |
| | #63 | |||
IWSTI Addict since: Feb 2005 Trader Rating: (3) | Quote:
Quote: | |||
| | #64 | |
130 Front 120 Rear Stretch is going to take some measurements on his stock tires. Once I have that number, I should have everything I need to repost the graphs. | |
| | #65 |
| Amateur STI Driver | |
| | #66 |
| Junior STI Driver | that would be per side I''m guessing, the WRX is roughly 100 front/90 rear per side- the 05+ STi has a beefier knuckle, larger calipers/larger rotors, heavier tires/wheels- so that would make sense- we're talking oe not any aftermarket |
| | #67 |
IWSTI Addict since: Feb 2005 Trader Rating: (3) | The main difference is this. In Fred Puhn's book How to Make Your Car Handle, he states that for the strut/spring combo, that you take the average of the the motion ratios at each end of the sturt/spring and multiply that by the weight of the strut/spring combo. For us, this is essentially one times the weight (vice 1/3 times the weight) I used 1/2 of the weight of the axles, control arms, later and trailing links. I will post up a list of the weights that I used later tonight. |
| | #68 |
| Silver Member
Car: Aspen 2005 STi Fav Mod: TurnInConcepts Coilovers Location: Silver Spring, MD Posts: 1,864
IWSTI Addict since: Mar 2006 Trader Rating: (2) | You still cut the weight of the spring and strut in half since part of it is sprung. In an inverted strut like on the STI, the part of the strut containing the oil is all sprung weight- it's the outer sleeve that is unsprung. I think it's is a pretty even weight split since the sleeves are made of heavy metal (surprising, as one point of an inverted strut is to save unsprung weight). Likewise the spring is half sprung since the top hat sits mounted against the sprung chassis. Control arms are probably more like 1/3 because they're fatter (heavier) towards the chassis, not that that's a huge deal. I'd be really surprised if unsprung weight is 130lbs, that's a LOT! I know the brakes are heavy, but the wheels are pretty light. Please post up the list, I'm curious. |
| | #69 |
| Junior STI Driver | here's the list for a oe WRX wagon FRONT tires- 22 lbs wheels- 16.5 lugs- .5 dust shields- .5 rotor- 14 caliper- 13 knuckle/hub 16.8 axle-12 control arm-10 strut assembly 19 REAR tires-22 wheel-16.5 lugs- .5 knuckle/hub 18.4 rotor- 9.5 caliper-6.8 lateral links-7 (both) trailing link 4 axle 12.2 strut assembly 17.5 I took the full weight of the wheels/lugs/knuckle-hub/rotors/calipers and half the weight of the axle, arm(s), and a 1/3 of the weight of the strut assembly. 101 lbs front/ 91.5 rear The RE070's are heavy 28 ish lbs? the 17x8 rims while relatively light for their size are still heavier than the oe 16x6.5 WRX rims, I'd be curious to see what the front knuckle/hub weighs- it's going to more than the WRX (the rear should be the same), the Brembos aren't exactly light either- nor the rotors. |
| | #70 |
IWSTI Addict since: Feb 2005 Trader Rating: (3) | Here are the numbers that I used. Front: Tire - 27 Wheel - 17 Lugs - 0.5 Dust Shield - 0.5 Rotor - 22 Caliper/Pad - 10.8 Knuckle/Hub - 22.5 Axle - 12 (0.5) Control Arm - 9.5 (0.5) Strut Assembly - 20 (0.985) Weighted Total: 130.7lbs Rear: Tire - 27 Wheel - 17 Lugs -0.5 Knuckle/hub - 22.5 Rotor - 18 Caliper/Pad 4.6 Lateral Link (both)- 4 (0.5) Trailing Link - 4 (0.5) Axle -12.2 (0.5) Strut Assembly - 20 (0.995) Weighted Total: 119.6 Note: AnorexicSTi posted that the rear knuckle/Hub was 22.5 lbs. I used this also for the front knuckle since I could not find any measurement for the front. Axles I kept the same as the WRX since I couldn't find any info on them. The various links I found estimates from Nasioc and I think they all came fom BigSky (thanks!). The axles are probaly heavier, but I wasn't going to guess at how much. If I change the weighting of the strut/spring assembly to 0.5, it comes out to 120.9/109.7 F/R. |
| | #71 |
IWSTI Addict since: Feb 2005 Trader Rating: (3) | In the above post, everything with a (#), the # is the weighting factor. If no number is listed, then the weighting factor is one. Last edited by 4banger; 11-13-2007 at 06:34 PM. Reason: spelling |
| | #72 |
IWSTI Addict since: Feb 2005 Trader Rating: (3) | I have reposted the origional graphs using the new unsprung weights. Even though you see a cell for the tire spring rate, it is NOT being used at this time. BigSky - I need to do some more work on the WRX dampers before I repost them. I fell bad that you are one of the few who posted about one of these setups and I ended up having to take your graph down. |
| | #74 |
| Gold Member
Car: 05 Subaru WRX STi Fav Mod: T2s and Recaros Location: Allentown, PA Posts: 3,329
IWSTI Addict since: Oct 2005 Trader Rating: (7) | I need to dyno the BCs when I take them off the car and upgrade. On full soft, the steering response noticeably slows, the car rolls a lot more and the ride becomes like a cream puff except over the biggest bumps. At setting 5, the ride firms up noticeably and the steering is more reactive. Bumps are felt a bit more but it is not harsh at all. At setting 10, ride firms up more, but not as noticeably. At setting 15, ride firms up more, noticeably over bumps. Reacts very well to steering input, little roll. At setting 20, its a go kart. Next to no roll, quick steering input, bumps start to hurt. At setting 25, same as 20 but the bumps hurt more. On full hard, its very stiff. I say punishing, but I don't remember it being as bad as the Swifts on stock struts driving into the bump stops. I haven't ridden on full hard in a very long time, even to autocross. I do remember the rebound being very strong and the car bouncing back one time from a hard bump very strongly. I couldn't stomach that on the street. |
| | #75 |
| The Next Petter Solberg Car: Silver 05 WRX STi Location: Tucson, AZ. Posts: 934
IWSTI Addict since: Dec 2004 Trader Rating: (0) | As has been said by a couple other people.....I am not as much into the whole mathematical calculations. However this thread has been a great read. There is 1 thing that was said in this thread that I strongly believe in. Someone mentioned that the smoother the surface, the less suspension travel you need (probably wasn't those exact words but close to it). There is 1 main reason why I have modified the suspension on every car I have owned......reduce body roll to keep the car as planted and stable as possible through twisties. I have learned that vehicle weight plays a HUGE roll in this. My last car (2001 2.5RS-T) weighed 2800 with me in it. It had JIC FLT-A2 coilovers with 8k/6k F/R spring rates, and 18x7.5 wheels with 215/40/18 rubber. That car felt more nimble and almost as stiff as my current car (2005 STi weighing around 3250lbs with me in it, with 255/40/17 tires on 17x8.5 wheels, Tein Flex coilovers 10k/8k F/R rates, Cobb 25mm hollow F/R swaybars rear set to middle setting). I hear a lot of people complain about how Flex's are over damped. For a very bumpy road this would be true, but for those smooth roads and smooth sections on a road course, I feel like they could be even stiffer. I guess I think there is no perfect suspension set up for every situation. There are gonna be times you want it softer, there are gonna be times you want it stiffer. I guess you gotta find that balance for the situations your car sees. Wow, that was a lot of ranting, lol. Looking at the plot for the Flex's on full stiff, I am not shocked at all. I run mine 1 notch from full stiff always, and I know there is almost no suspension travel at all in both bump and rebound. For daily driving, small bumps are not a big deal and I didn't notice much of a difference going from stock to Espelir GT springs to Flex's. For big, or abrupt bumps, the Flex's hit them VERY hard and there is a huge difference from stock and Espelir GT's to the Flex's. I don't have any "hard" data to add, but I thought I would share my thoughts and experiences with this type of thing. This ad is not endorsed by this member. Please register or login to hide this ad. |
