Old 10-19-2007, 03:04 PM   #1
Fav Mod: Greddy T-ic
IWSTI Addict since: Apr 2007
Send a message via AIM to sti_nguyen
Default 04 lower control arm (front) 04 STi
Is there a difference between 04/05 lower control arms and 06/07? Are the 04 sti lower control arms made out of aluminum?
sti_nguyen is offline   Reply With Quote
Old 10-22-2007, 06:48 AM   #2
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Default Re: 04 lower control arm (front) 04 STi
The 04 and 05 are aluminum. I don't remember when the switch was, but I'm pretty sure the 07's at least at stamped steal.
Tony
Old 10-22-2007, 07:31 AM   #3
Car: 07 STI Limited
Fav Mod: all of them...
IWSTI Addict since: Nov 2006
There was an article from Subaru in Performance mag that stated the Limited and maybe the regular STI's were to have steel control arms and other bits but as I know those who have check including my 07 STI Limited have the Aluminum versions. The other differnce is thaat the 05's have the Spec C version as OEM US Equpment with more caster. This changed and went back to the non-spec C version in 06.
speedmonkey is offline   Reply With Quote
Old 10-22-2007, 02:48 PM   #4
Fav Mod: KONI+Swift+Zzyzx=Win
IWSTI Addict since: Jul 2007
The 07 has a different part number than the 04-06...the 07s are aluminum, but I believe they are the non-Spec C versions....based on the 07 having the 99.5" wheelbase compared to the 04-06's 100" (with the spec C arms)
boxer_four is offline   Reply With Quote
Old 10-22-2007, 03:49 PM   #5
Trader Rating: (53)
Bingo. Also the 04 and 05 may differ slightly due to the tab placement for the endlinks. This is from the long switchover history of front bars.
-clint
Old 10-22-2007, 04:53 PM   #6
Then what are the 04's lower control arm made out of? i ordered a control arm from the dealership for my 04 sti and it was aluminum... It even says that on the receipt.. 04 sti lower aluminum control arm
Old 10-22-2007, 07:02 PM   #7
Car: 07 STI Limited
They are Aluminum! If you really need to check you can always try the magnet test.
Old 10-22-2007, 07:19 PM   #8
04-07 are ALL aluminum...just differing geometry.
Old 10-22-2007, 07:21 PM   #9
Oh and I also forgot...the 07s have the little tabs for mounting roll sensors (even though the USDM cars don't have the sensors)
Old 10-28-2008, 03:53 PM   #10
Car: PSM 02 Bugeye
IWSTI Addict since: Oct 2008
Then why do the control arm kits for the say 04-07? Would there be a negative affect putting the 07's on over the 04's on a bugeye?
OHARA is offline   Reply With Quote
