Old 10-18-2007, 05:32 PM   #1
IWSTI Addict since: Jul 2005
Default Infamous rear clunk
I have read a least a dozen threads so far. Some say the rear clunk killer helps and others say it did not fix the problem. Here' my description of it.
When engaging first gear I here a clunk in the rear. Not sure if its from the passenger rear or rear center. I also here it on deccleration to acceleration. It has been getting progressively worse over the last few months. What is the prognosis and the cure.
SubySteve is offline   Reply With Quote
Old 10-18-2007, 06:15 PM   #2
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Default Re: Infamous rear clunk
The klunk killer is NOT for low speed/low RPM clunks. People just aren't paying attention when they say they bought that kit, and it didn't fix that.
The Klunk Killer is for the HIGH RPM/HARD shifts that cause the rear diff to slam around in its mount.
Old 10-18-2007, 06:23 PM   #3
Fav Mod: UR GT35r
IWSTI Addict since: Jul 2007
Send a message via AIM to fractur3
so what fixes the low speed? cause thats what i need
(i saw you today when i was gettin on 75 south by the wal mart)
fractur3 is offline   Reply With Quote
Old 10-18-2007, 06:28 PM   #4
Fav Mod: Fixing Subie Rattles :)
IWSTI Addict since: Jan 2006
Send a message via AIM to SiCkSTi04
TiC is right, i bought the kit and my poor diff was saved!
SiCkSTi04 is offline   Reply With Quote
Old 10-18-2007, 07:56 PM   #5
Trader Rating: (53)
It depends on what it is. Keep in mind that diff is noisey to begin with.
I didn't see you - what were you driving?
Old 10-18-2007, 07:58 PM   #6
Fav Mod: UR GT35r
i was in my brothers white explorer, i had to run to the wal mart to pick up 2 more jack stands to put my g200 on lol
Old 10-19-2007, 02:00 PM   #7
Car: STi Pastelito Racing
Fav Mod: I have 18L of fun
IWSTI Addict since: Mar 2006
dude tighten your rear axle nuts!
rich728 is offline   Reply With Quote
Old 11-14-2007, 06:52 PM   #8
IWSTI Addict since: Sep 2007
Tighten your rear axle nuts yet? Any more clunk?
ikoinu is offline   Reply With Quote
Old 11-14-2007, 10:34 PM   #9
Car: 06 AW STI
Fav Mod: BC Coilovers
IWSTI Addict since: Sep 2004
Send a message via AIM to boostin04
Are the rear nuts known to come loose ? I get a clunk everytime i put it in reverse and back out, its real audible from outside the car too...
boostin04 is offline   Reply With Quote
Old 11-14-2007, 10:42 PM   #10
Car: Pearl White 07 STi
Fav Mod: Left foot, Right hand, then my right foot!
IWSTI Addict since: Jun 2007
Are you sure its not the brakes?
GoLawrence is offline   Reply With Quote
Old 11-14-2007, 10:55 PM   #11
Car: 06 AW STI
Could be that too...theres all kinds of noises from this thing..haha But i still love it....but well see what happens once i get my brake upgrades done...
Old 11-15-2007, 02:06 AM   #12
Backing up could be a strut clunk. But for the record, there's also the low speed throttle clunk, the highspeed shift clunk, the uneven pavement or speedbump clunk, and the turn clunk. The one he was talking about was the low speed shift or throttle clunk, which can be the rear diffs too loose bushings, or the axle nuts loosening up. The highspeed clunk is also bushing related, whereas the speedbump/ turn clunk tends to be either loose strut top mounting bolts, dry strut (requiring grease on the shaft), or worn(pillowball ie-factory), dry(bushed ie-Kartboy), or loose(both) swaybar endlinks. Could always be the jack or jack accessories in the spare tire well also (obscenely obvious but often overlooked). There. I think that about covers it!
Old 11-19-2007, 08:52 AM   #13
Car: Silver 05 WRX STi
Fav Mod: Advan RGIIs
IWSTI Addict since: Apr 2004
Tighten your rear axle nuts. This thread sounds very similar to what I had. Once I got them tight clunk noise went away. It happens. Easy/cheap fix. At least start with that before you buy anything. Actually, I think you need to buy new axle nuts but can't recall at the moment. It is under warranty if you are not past that so it is at least worth a look IMO. Either way, it is a cheap fix.
mdefalco25 is offline   Reply With Quote
