| | #16 |
| Is Scared Of Kevin...
Car: 2007 WRX STI Limited Fav Mod: APS Catless R1 TurboBack Exhaust Posts: 3,031
IWSTI Addict since: Nov 2006 Trader Rating: (5) | could someone from tic pm me thier phone # so i can discuss a suspention setup with them so i can purchase it....... This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #17 |
| Junior STI Driver | With both the Sportline and Flag being fully spec'd and assembled in Japan- I would guess that has a lot to do with the choice of damping and the choice in overall travel. It has been my experience that the Japanese tend to choose relatively short travel and very firm damping, this probably is at least in part to their road system. If the Sportline or Flags were spec'd in the US or even the EU, they most likely would look different. |
| | #18 | |
| Halliburton Mercenary | Quote:
| | #19 |
| Halliburton Mercenary | oh... thanks for the reading stretch. found your post, and here are the two links: Shock Absorber - Shock Dyno - Reading Shocks - Circle Track Magazine Shock Absorber Tech - Overview - Suspension Tech - Circle Track Magazine Last edited by fullerton; 10-17-2007 at 05:18 PM. |
| | #20 | |
| The Hoff Fan Club, member #001 Car: 05 WRB/Gold Fav Mod: Hood Scoop Homer Location: Where ever The Hoff is! Posts: 10,373
IWSTI Addict since: Jul 2004 Trader Rating: (4) | Quote:
I was under the impression they were spec'd in europe (are they from holland? i dont remember), and then just assembled in japan. | |
| | #21 | |
| Amateur STI Driver | Quote:
My understanding is that it is common with digressive shocks to have the damping factor around 1 (or even much higher) at low speed. Remember that the shocks are also damping the sway-bar in cornering. I've recently acquired a set of the acclaimed Exe-tc track coilovers and they follow the philosophy of softish springs with highly digressive damping and on first impressions they are much more heavily damped in the low-speed than the Ohlins. Unfortunately I don't have a dyno chart for them. I'll dust-off my own suspension calculator and see what damping factor it gives for these Ohlins. It calculates df by integrating force from 0 to 1m/s which is somewhat arbitrary but suits my needs. That produced a df of around 0.28 for my ASTs which I found to be under-damped. Millican advises a df of 0.25 for comfort up to 0.6 for performance but that seems to be based on linear damping (constant over all velocities). | |
| | #22 | ||
| Silver Member
Car: Aspen 2005 STi Fav Mod: TurnInConcepts Coilovers Location: Silver Spring, MD Posts: 1,864
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Quote:
I expected to see ~70% critically damped initially tapering to 50% or so at "street" settings. My "track" expectations were a little more relaxed but I still expected them to at least taper back to ~65%. Only the rears do that, but they also show much less digression. I wonder if there's something the dyno isn't showing, such as hysteresis or an attenuation on very small strokes, that could be playing a large role. Quote:
| | #23 |
| Junior STI Driver | my understading is that Ohlins Japan spec'd the setups, Ohlins "home" provides all the bits they need to achieve it- for the longest time the only market the Sportsline and Flags were offered was Japan irregardless it appears these coilovers at least roughly follow much the general Japanese line of thinking of firmly damped, relatively short stroke However- Arnie brought up a good point at the other fourm ( ) that not everything is revealed in a dynograph, Duncan alludes to this as well |
| | #24 |
| Silver Member
IWSTI Addict since: Mar 2006 Trader Rating: (2) | ...but most things are revealed on a dyno, and everything should be measurable with the right test. Speaking of, here are the Ohlins Flags. A user here rbahr sent these to me back in May and I totally forgot about them. TiC had me digging for stuff to compare, and I found them again! ![]() ![]() ![]() Overall they are still quite stiff. At a glance compared to the Sportlines (doing unit conversions in my head), they look softer and rebound with more adjustment, but a little stiffer in bump. So, they're less overdamped than the Sportlines, though I don't think it's enough to fall into the 65-70% critically damped range. The Flags come with slightly stiffer springs. I'll have to plot these to see the critically damped percentages. Last edited by stretch; 10-18-2007 at 07:54 AM. |
| | #25 |
| Gold Member
Car: 05 Subaru WRX STi Fav Mod: T2s and Recaros Location: Allentown, PA Posts: 3,329
IWSTI Addict since: Oct 2005 Trader Rating: (7) | the Flags there look like they have lots of overlap? |
| | #26 | |
Thats just what I did in my program to get a single damping factor figure, like I said its arbitrary. Millikan says nothing about velocity sensitive dampers - its pretty old-school academic stuff. I don't think you can say these Ohlins are way overdamped without actually driving on them. At least until you have your methodology calibrated against real-life. As I said the valving on these seems similar to whats on mine and the ride is civilised. I haven't experienced the Tein Flex so can't comment. I tried running my program but its broke on XP Its a toy quarter-car time-domain simulator I knocked up to try and get a handle on the dynamics of non-linear dampers. | |
| | #27 |
| Authorized Vendor | here's the thing that bothers me on this. Do we know that 65-70% is ideal for this car, and under what conditions? What gets me thinking this is the math vs. the real world feel. While the numbers (and, Stretch, I do believe you have them correct unless we're both missing something major) show that these should be rather overdamped I have to argue that they feel fantastic when put on the car and driven. So, where are we seeing the disconnect, and why? |
| | #28 | |
| Junior STI Driver | Quote:
| | #29 | |
| Authorized Vendor | Quote:
Now, I have many many books on suspensions, but the best all around book is the Milliken. In it they have a forumula for critical damping which is Ccritical =2* sq root of k*m (sorry don't know the ascii code for square root) k is spring rate m is mass The relationship of damping coefficient C at Ccritical is C/Ccritical | |
| | #30 |
| Authorized Vendor | Ok. I may have found something. I've got to run to my kids halloween party at daycare, but I'll post up more when I get a chance. This ad is not endorsed by this member. Please register or login to hide this ad. |
