| Platinum Member Car: Silver Euro 07 STi Fav Mod: Modify the law! Remove the speed limits! Location: Philippines Posts: 609
IWSTI Addict since: Dec 2006 Trader Rating: (0) | Hi guys. I'm about to order WL swaybars and endlinks, I see other guys put WL SB and kartboy endlink. Why not WL SB and WL endlink? Is there any problem with WL endlinks? Has anyone used the WL 27mm rear SB? I found it here Import Image Racing Webstore I'll run the car on the race track and will also buy coilover, I'm thinking of buying Tein + EDFC. Please give your comments. Thanks This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 |
| Professional STI Driver | I have the solid white line endlinks on my 27-29mm front bar and 22-26 rear bar and couldnt be happier. Nothing hits, nothing pops, I hear no squeeking. I dont think whiteline makes the solid endlinks any more, which is the reason alot of people get the kartboys. However alot of people seem to have issues with the kartboys hitting the tie rods and the endlinks being at really funky angles. |
| | #4 | |
| Silver Member Car: 07 Subaru STi Fav Mod: Coilovers/Tune Location: NY Posts: 1,231
IWSTI Addict since: Nov 2006 Trader Rating: (0) | Quote:
| | #5 |
| Spec C Club | I'm using Kartboys and am very happy with it. Zero noise, and no problems with the clearance although it will be close with 27-29mm FSB. |
| | #6 |
| Professional STI Driver Car: Aspen White 04 STi Location: Bristow, VA Posts: 421
IWSTI Addict since: May 2003 Trader Rating: (0) | rookie84, where in NOVA are you? You think you can take me for a spin? I just want to see how a 27mm would compare to my stocker. Just a thought, let me know if you can. |
| | #7 |
| Spec C Club | Sorry, I'm in Ohio right now for school... but there are many in NOVA that are running the same swaybar combo. Just post in mid-atlantic regeional forum and ask for a ride. I'm pretty sure someone will give you one. |
| | #8 |
| Senior STI Driver Car: CGM 05 STi Fav Mod: apr rear diffuser Location: Tampa Posts: 313
IWSTI Addict since: Mar 2006 Trader Rating: (0) | I bought the kartboy endlinks b/c they were less money. There was a website that had a deal on them where you could buy them for like 180 for both front and rear. Hell, they are just as good as the whitelines, just better on price |
| | #9 |
| Authorized Vendor Car: 2008 Pinarello FP5 Fav Mod: New Underwear after a 147mph slide into turn 17 at Sebring in the rain....still got 3rd.. Location: Columbia, Maryland Posts: 3,411
IWSTI Addict since: Apr 2005 Trader Rating: (10) | The advantage to the adjustable pillowball Whitelines is that the length can be adjusted so you can properly corner balance the car if you are on coilovers. 99.9% of the time though, we stick with Kartboy because they are dead silent, strong, and have a great price. - Andrew |
| | #10 |
| Authorized Vendor | That's the standard combo pack price. Any of the US Kartboy dealers should be able to give you that price for purchasing the front and rear together. |
| | #11 |
IWSTI Addict since: Mar 2006 Trader Rating: (0) | well, thats nice to know. Good luck on your choice of endlinks man! The kartboy's are nice |
| | #12 |
IWSTI Addict since: Dec 2006 Trader Rating: (0) | Thanks for the reply guys. If I buy Whiteline 27mm Rear Sway bar for 04+ STI [BSR37XXZ] do I need Whiteline Sway Bar Mount Kit for the rear? I biggest mount kit I found so far is for 24mm only. Do you guys know if WL sells the mount kit for the 27mm rear? Thanks again |
| | #13 |
| Spec C Club | I went with WL and KB endlinks because of the price! The KB Endlinks are cheap! Although, I ran in problems with my endlinks hitting my tie rods .. which is a PITA so I have to check it every so often .. to see what's wrong. Sometimes I fix it and I don't hear anything for months but every so often I hear grinding .. If money isn't a problem, I would recommend the WL endlinks. |
| | #14 | |
