Go Back   IWSTI.com: Subaru STI Forums > Owners' Lounge > Sanctioned Motorsports
Old 07-21-2008, 01:28 PM   #46
Fav Mod: Ohlins struts
Default Re: Most important mod for autocross
My recommendation for starting in STU:
- Good street tires (Falken RT615's, Bridgestone RE01R's, Dunlop Z1's, Toyo R1R's, something like that)
- RCE lowering camber plates
- And lastly, I'd use the following alignment:
Front:
-2.0 degrees camber
0 toe
Rear:
-1.6 degrees camber
0 toe
These modifications should improve the balance and feel of the car while also improving lap times regardless of skill level. And this alignment can be used for street driving without any terribly uneven tire wear. I do it, and you'd never know it by looking at my tires.
And no camber bolts should be needed for this. At stock ride height rear camber should come to around -1.6 degrees give or take a tenth and that's fine. And the RCE lowering camber plates will allow up to around -2.2 degrees front camber with the stock struts. Unless you're wanting some super-aggressive camber, in my opinion these are the best camber plates to use on an otherwise unmodified suspension.
SWortham is offline   Reply With Quote
Old 07-21-2008, 03:59 PM   #47
Car: 07 Subaru WRX STi Bl
Fav Mod: APS INTAKE
Send a message via Yahoo to manny07sti
Front:
-2.0 degrees camber
0 toe
Rear:
-1.6 degrees camber
0 toe
And no camber bolts should be needed for this. At stock ride height rear camber should come to around -1.6 degrees give or take a tenth and that's fine. And the RCE lowering camber plates will allow up to around -2.2 degrees front camber with the stock struts. The other benefit of these lowering plates is that they actually increase bump travel slightly, and they don't hurt ride quality at all. Unless you're wanting some super-aggressive camber, in my opinion these are the best camber plates to use on an otherwise unmodified suspension.
So do you think -2.5 camber is bit much.
manny07sti is offline   Reply With Quote
Old 07-21-2008, 05:31 PM   #48
Oh, I don't know... I mean the nationally competitive guys tend to run -2.5 to -3.0 degrees camber I think. But if you're like me and you hate to mess with your alignment for every race then it's nice to have a setting that's a good compromise for everything. Of course that setting depends on how much autocrossing vs street driving you do I suppose. But yeah, I'd expect a little more uneven wear with -2.5 degrees.
Old 08-01-2008, 05:59 AM   #49
Car: 2005 STi
Fav Mod: Empty passenger seat
Send a message via AIM to WRXBrakes
a good seat?
WRXBrakes is offline   Reply With Quote
Old 08-01-2008, 08:33 AM   #50
Teh Other White Meat
Trader Rating: (22)
Originally Posted by WRXBrakes View Post
a good seat?
Good point. However, you can't swap out seats in stock category and a good harness is cheaper than new seats and still very effective.
My Scroth quick fit harness was a great investment. I used to get a sore left knee from bracing myself using the dead pedal. Being strapped in also gives you a feeling of more control. I am no longer sliding all over the ****pit, constantly adjusting myself to brace for left and right turns. It's less fatiguing I think.
Old 08-01-2008, 08:36 AM   #51
Car: 2005 STi
anything to keep from having to brace yourself -
Schroth 4points on an 02 WRX seat wasn't bad at all -
Old 08-01-2008, 10:15 AM   #52
Car: 2007 STI LTD
I have been running -2.4* camber for about a year and have more wear on the outside of my RE070s [which I race STU and do HPDE days with] and only 1/32 more wear on the inside of my winter all seasons [which I use from Nov- March or April]. So the camber is not that critical for tire wear.
BTW: is someone censoring the word "****pit" because that is obscene? Why the ****ins would you do that?
XDNBC is offline   Reply With Quote
Old 08-01-2008, 10:27 AM   #53
i eat cones
Fav Mod: 18x8
Trader Rating: (18)
honestly, seat time.
or a harness. lol also, make sure to save up for new tires
Old 08-01-2008, 11:01 AM   #54
Trader Rating: (22)
toe is going to have a far greater effect on tire wear. combine some toe with a lot of camber and you will get accelerated inside shoulder wear.
