Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > General > STi Sanctioned Motorsports
Old 07-12-2007, 01:11 PM   #31
Car: '99 M3/'03 WRX Avant
Fav Mod: Modification is wrong!
Default Re: Most important mod for autocross
Originally Posted by rankink75
The stock boost curve must be maintained for ST classes and thus you can not touch it when tuning. This includes bumping up the rev limit as it could be conceived as changing the boost curve since there was no curve above 7k rpms prior. With typical STU modifications you will get 1-2 psi higher without changing the stock ECU boost parameters. This is acceptable in ST classes as it is a direct result of opening up the exhaust while not touching boost under the rules.
This is not 100% true. A change in boost behavior due to a rev limiter modification would be an indirect change to the boost. Kind of a silly example anyways given that the ECU does define behavior above red line or even outside of the defined maps.
The cobb map is made with aggressive timing/fuel curves and the resulting boost from bolting on a better designed downpipe while running 100 octane. Map information can be attained by reading the maps notes.
STirish is offline   Reply With Quote
Old 07-13-2007, 03:05 AM   #32
Car: 05 Subaru WRX STi
Fav Mod: SFSOC / Pastelito Racing
Well, until it comes up against a official national protest we will not know for sure.
rankink75 is offline   Reply With Quote
Old 07-14-2007, 10:52 PM   #33
Just go to SM, thats what I did.
No wories about ECU map changes
offroadracer99 is offline   Reply With Quote
Old 04-09-2008, 08:07 PM   #34
can you add a prodrive bcs but keep stock levels?
wrxcelration is offline   Reply With Quote
Old 04-09-2008, 08:54 PM   #35
killer ants in your pants
Trader Rating: (21)
not for AS or STU
Old 04-10-2008, 02:44 AM   #36
Ok just wanted to make sure as Im getting a tune w/ chris from xx and I want to utilize all the parts I can. So an aps65mm intake, and gms turbo inlet and aftermaf hose will be ok to install as long as I have an STU map correct? Sorry if its been asked before but Im a noob this year to STU and the intake rule is a little confusing. Thanks.
Old 04-10-2008, 06:05 AM   #37
Car: 05 Blue/Gold
Fav Mod: Blinker Fluid and Piston Return Springs
As long as you don't have to do anything else to install this stuff, it should be legal, as it is all ahead of the compressor inlet. I read somewhere that some of the inlets require that you move some other stuff around, and that may not be completely legal. In other words, you can't do something illegal to make a legal mod work. I am not familiar with the turbo inlet and hose, so I can't tell you which way it falls.
IlliniSTi is offline   Reply With Quote
Old 04-10-2008, 09:07 AM   #38
can anyone else clarify more on the cai and turbo inlet for STU
Old 04-10-2008, 09:39 AM   #39
Trader Rating: (21)
sure: http://scca.org/documents/Solo%2...lo_Rules_2.pdf
Old 04-10-2008, 10:57 AM   #40
Car: 07 Subaru WRX STi Bl
Fav Mod: APS INTAKE
Send a message via Yahoo to manny07sti
Im also very new on the Auto-X seen. Im thinkin my sways were the best mod.
manny07sti is offline   Reply With Quote
Old 04-10-2008, 11:45 AM   #41
Car: 05 Blue/Gold
The CAI is legal as long as you don't have to modify the body to get it in. I got the 65 APS in without having to get out the dremel, so I know that is legal.
Here is a thread on NASIOC about the legality of the APS turbo inlet, which may be similar to yours:
APS inlet STU legal? - Motorsports - NASIOC
Old 04-10-2008, 12:03 PM   #42
I read the rules..I was just confused as inlet I just wasnt sure to compressor or turbo inlet. Ill be running the GMS inlet w/ the aps 65mm
Old 04-17-2008, 04:33 PM   #43
Fav Mod: Motor Mounts
Tires are the #1 mod next to seat time. Period. Next up camber and coilovers.
polyol is online now   Reply With Quote
