Go Back   IWSTI.com: Subaru STI Forums > Owners' Lounge > Sanctioned Motorsports
Old 06-05-2008, 10:24 PM   #1
Car: 06 STi CGM
Send a message via AIM to stevos758
Default 245 in a stock?
Can I run 245/45/17's in the A stock class on an STi?
stevos758 is offline   Reply With Quote
Old 06-08-2008, 02:15 PM   #2
Default Re: 245 in a stock?
Tire size is unlimited in Stock classes. Run as wide as you can fit. I have seen several A Stock pre-08 STIs running 275 width tires on stock wheels.
matthuntman is offline   Reply With Quote
Old 06-10-2008, 04:05 AM   #3
Car: 06 CGM
I've even seen 275's on the 04 7.5" wheels.
If you are going to run 275's on stock wheels though you'll need a ~5mm spacer for clearance with the strut. Or you could get a wheel that has a 47-48 offset instead of the spacer. Remember that stock allows for for a +/- .25" (6.35mm) variance in offset...anything greater than that is not legal in stock class.
The guy's in the 08's+ are able to fit 295's easily.
The_Wolf is offline   Reply With Quote
