| Platinum Member Car: 04 silver STi Fav Mod: More seat time Location: CT Posts: 209
IWSTI Addict since: Jan 2006 Trader Rating: (1) | Does anyone know the minimum temperature that V710's will be effective? I ask because the first Ax of the year will be 4/13 up here in Ct. It could very well be in the 50's that early in the year. If the tires won't be effective or chunk up from the cold I'll just run the 070's. Thanks. Jeff This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Senior STI Driver Car: 04 STi Fav Mod: so far? RCE T2s Location: kansas Posts: 387
IWSTI Addict since: Oct 2004 Trader Rating: (0) | it was 61 degrees at Nationals at the start of my heat and my Kumhos sucked. No codriver and too much time between runs did not help me. Part of it was Kumhos at Topeka and part of it was a sandy Topeka course. I had advice to drop tire pressures down to 26-28 psi which I ignored and probably contributed to the problem. That said, the kumhos are going to be just as warm as the RE070s and will be the better tire. the exception is thatr road heat will warm up the RE070s. |
| | #3 |
IWSTI Addict since: Jan 2006 Trader Rating: (1) | Thanks for the info. Do you feel running pressures that low would have been beneficial at those temps? How much lower would that have been over your normal pressures? |
| | #4 | |
IWSTI Addict since: Oct 2004 Trader Rating: (0) | Quote:
Last year I ran 36 fr and 32 rear before I got camber plates I'd run 40 fr and 36 rear and higher, just to prevent the shoulders from rolling. | |
| | #5 |
| Professional STI Racer
Car: 02 Penis Extender Fav Mod: Autotrader.com Location: Philly Posts: 822
IWSTI Addict since: Jan 2006 Trader Rating: (1) | I asked this same question on Nasioc before our first event of the year. My first run heat it was 35 degrees and my A6's were just fine. It was about 55 degrees during the second heat and they were even better. Not abnormal wear or anything either. This ad is not endorsed by this member. Please register or login to hide this ad. |
