Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Marketplace > Vendor Classifieds > Archived Vendor Classified Threads by Vendor > StaticX Motorsports
Closed Thread
Old 06-08-2005, 01:28 PM   #46
Car: 05 Subaru WRX STI CG
IWSTI Addict since: Aug 2003
We will be replacing all paypal links with store links as our new system will accept paypal, credit cards, etc without any problems or issues. Thank you!!!
Robert~
staticx313 is offline
Old 06-08-2005, 01:44 PM   #47
New link and coupon for turbo wrap kit is up. I will have the downpipe and combo link up momentarily. Thank you!
Robert~
Old 06-08-2005, 01:57 PM   #48
Downpipe link added. Use coupon to get the IWS discount. If there are any issues or problems, please let me know. Thank you!
Robert~
Old 07-23-2005, 05:56 AM   #49
Fav Mod: TiC AST's - 7/6K
IWSTI Addict since: Feb 2005
Default couple of quick install questions
Couple of quick install questions. Any help will be greatly appreciated. How tight is this wrap suppose to wrap around the turbo? I think I have it on there pretty good, but can't seem to make it very tight. Is this going to matter. Also, are you suppose to cut a notch around where the wastegate actuator arm is? It seems like if you don't you won't get it to cover around there well. If anyone has any suggestions, please let me know. Thanks
4banger
4banger is offline
Old 07-26-2005, 09:52 AM   #50
It would not necessarily have to be SUPER tight. You do however want it to fit snug if possible. Meaning, its best to try and use 2 needle nose pliers to pull it tight (so it does slide around/move). Just dont yank it do death is all =P. The area where the actuator arm is, the wrap should actually sink down between the housing/flange. Let me know and I can see if I can be of more help there. Thank you!
Robert~
Old 07-27-2005, 06:55 PM   #51
Robert, I am going to try tightening it a bit with needle nose pliers like you suggested. My wrap seems like it just didn't want to fit, but maybe I could have pulled it closer to the actuator arm. I have a lot of uncovered area around the arm. I just didn't want it to interfere with the swing of the arm. The pics you have up are good, but think would be better if you had a top down pic of the stock turbo wrapped so you can see what it looks like when you are trying to install it on the car. Thanks.
4baner
4banger is offline
Old 07-28-2005, 12:04 AM   #52
4baner
I will try to get you some pictures as soon as I can. If you can grab any let me know. It should cover the main section of the housing, but due to the shape of the flange, being that its internally wastegated, it may cover that perfectly (which is ok). You mainly just want the hump which will retain the heat covered. Thanks and we will see what we can do for ya.
Robert~
Old 07-28-2005, 12:47 PM   #53
Robert, I just zipped a pic to you via email. You are welcome to post it up if you want.
4banger is offline
Old 07-28-2005, 08:20 PM   #54
Default bad news
Today I tried installing my new downpipe. I had to adjust the heat wrap some to get access to the top two bolts. While doing that the hold side gave way and the metal string just ripped right out. Hopefully I can sew it back up and make it work again.
4banger is offline
Old 07-30-2005, 08:50 AM   #55
Wes, As I stated in the Email, if you cannot make it work, we'd be more then happy to send you another piece to make this work. I am going to grab a picture today while I am working on my car and will send it to you via email and/or post it. Thank you and we're sorry about the trouble with this. Just let us know how to make it work and we will do whatever we can.
Robert~
Old 07-31-2005, 04:31 PM   #56
Default Robert stands behind his parts
Thanks Robert, you have really been going out of your way to make sure that I am happy. I don't want anyone to think that the turbo wrap kit is bad. The kit does a great job at holding the heat in and keeping things cool around the turbo. Just make sure you get it on the way you want it before you go driving around. Once it gets hot, it molds into place and doesn't like to be adjusted. Don't make the same mistake that I did and think you can take it back off install a downpipe.
4banger is offline
Old 08-01-2005, 01:35 PM   #57
lol we try our best Let me know how you want to resolve this.
I am still going to grab some pics today, just been majorly busy.
After looking at mine again, the side closest to the flange/actuator is molded in, but the other side is barely able to mold in due to the design of the housing. So I guess just try to mold it in on the flange side as well as you can and a little bit on the other side.
brb with some pics.
Robert~
Old 08-01-2005, 01:48 PM   #58
Car: ST"I" '06
Fav Mod: Handling
IWSTI Addict since: Jun 2005
does your kit come with sealant (or already sealed wrap)
because wraping is memorable to ignite itself when oil is spilled on it ...
if not it'S possible to put some sealant on it ? from who and where i cant find it if it's possible..
i'm interested in wrapping downpipe up pipe turbo .. but the risk of fire make me think more about that...
Rain
RainMan is offline
Old 08-02-2005, 04:04 PM   #59
Rain
The StaticX kit does not come with any sealant or glue. They have run theirs for 4 months with no problems. Just put the stock heatshield back on any you shouldn't have any problems with oil getting on the wrap.
4banger is offline
Old 08-04-2005, 08:35 AM   #60
lol how would you be getting oil on it? If you're going to replace the turbo, let it set for a long time and there will be no oil when you remove it. Otherwise I don't see how you would be getting oil on it? If you get oil on it, I would recommend replacing it, but I dont think that will happen.
I would be careful wrapping anything before the turbo (I'd recommend coating it). The amount of heat that builds up between the engine and turbo is very high, so keep some fire exts on standby if you do. We've not had a problem with wrapping our turbo or the downpipe, but I have not wanted to touch the uppipe or headers yet. Good luck and let us know if you end up doing that.
Robert~
Closed Thread
HTML code is On
