Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Driving & Motorsports > Sanctioned Motorsports
Old 08-15-2007, 08:32 PM   #1
IWSTI Addict since: Apr 2007
Default Rear camber ?s for autox
Can I get back to -1 or -.5 rear camber from -1.3 and -1.6 stock? I want to get a bit more rotation and just want to see if I can do it with the stock bolts and parts. Right now I have an 06 with Whiteline 29mm front and 24mm rear and I have the stock tires still which I run at 37 F and 45 R. This isn't too bad but I'd like to get that rear tire pressure down some. I also have one more spot higher on the rear bar but I want to get some better rear endlinks before I use that. Even if I can get -1 that would be ok.
Dark_Helmet is offline   Reply With Quote
Old 08-15-2007, 08:34 PM   #2
IWSTI Addict since: Aug 2006
Trader Rating: (15)
Default Re: Rear camber ?s for autox
WOw 45 psi. I gottah try that. Really get that back out
Old 08-17-2007, 05:07 AM   #3
Fav Mod: so far? RCE T2s
IWSTI Addict since: Oct 2004
camber bolts are available from a number of sources would allow one to reduce the rear camber. You can use them in any of the non-stock classes.
Old 09-02-2007, 12:08 AM   #4
Car: 06 STI
IWSTI Addict since: Dec 2006
with the stock bolts it's not possible. Only way is to lobe the struts.I used camber bolts and have the rear set to -0.5R and -2.3F0 toe all roundCar rotates amazingly!
mojambo is offline   Reply With Quote
Old 09-02-2007, 12:15 AM   #5
Car: '06 STI
Fav Mod: air freshener!!!
IWSTI Addict since: Jan 2006
DH,
Interesting approach and #'s. I'm surprised they are working for you.
