Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Driving & Motorsports > Sanctioned Motorsports
Old 04-12-2005, 04:14 PM   #1
Car: 2004 STi
IWSTI Addict since: Apr 2003
Default PWRC car setup information
This Subaru link lists the different rallies in the PWRC and the setup each factory Spec C used for each rally. Very good information down to the alignment and wheel arch heights.
bookmark it because rallies will be added as the season progresses.
http://www.subaru-sti.co.jp/e/GRN/tec_info/index.html
Old 04-12-2005, 09:24 PM   #2
RiX
Car: Driving
Fav Mod: Driving school... GT35R :)
Am I reading it wrong....?
I noticed that Gr.N. front / rear cambers are only -3 ~ -1 degrees. I thought most of you guys with so-called performanced alignment were at -10 to -15 degrees of camber.
RiX is offline   Reply With Quote
Old 04-12-2005, 09:29 PM   #3
Car: 2004 STi
no, those numbers are correct. -10 or -15* camber would make the front tires look pretty seriously tilted inward and would have almost zero contact patch.
notice how the wheel arch height and alignment settings change for different gravel rallies vs. tarmac rallies. Also the diff preload settings are listed for the tarmac rallies. This is valuable information if you are looking to figure out where to start with a setup. the details of the stage conditions are easy to find, so you can kind of figure out what is important for different conditions.
