Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > ECU Tuning & Performance Electronics > Review STi Tuners
View Poll Results: How would you rate your experience with this tuner?
Acceptable 0 0%
Less than Acceptable 0 0%
Voters: 0. You may not vote on this poll
Old 03-12-2006, 07:01 AM   #1
Fav Mod: Not working in the Summers!
IWSTI Addict since: Apr 2005
Default Logic Imports Protune (Boulder, CO) Results
Chris at Logic produced very nice gains. I began the day at 245.1whp/275wtq (Blue) and left his shop at 257.3whp/300wtq (Red). All of this with lowering the turbo's psi. The new protune curve (hp & tq) from 2000rpm to 5500rpm is very impressive. Chris does great work, I recommend his shop.
Should I perform the "Vishnu Ignition Advance Multiplier" thing or can I just let the car "learn" the new protune map over the next few days?
RUGBY is offline   Reply With Quote
Old 03-12-2006, 08:28 AM   #2
IWSTI Addict since: Dec 2004
Great tune Rug! Looks almost identical to my LI Protune...
Just let the car relearn the tune..it only takes a day or two depending on how much you drive. Looks great...Chris is the man!
Brahmzy is offline   Reply With Quote
Old 03-12-2006, 10:48 PM   #3
Car: 06 Subaru WRX STi: A
Fav Mod: exhaust
IWSTI Addict since: Oct 2005
just curious what power mods have been done to the car. I'm assuming these numbers are a protune with the Cobb AP at stage 1.
battlecat is offline   Reply With Quote
Old 03-13-2006, 07:57 AM   #4
Aww geez...here we go with the whole explaining the conservative dyno at high altitude thing again... Rug, I'm done with this...care to chime in?...
Old 03-13-2006, 08:02 AM   #5
NIИja
IWSTI Addict since: Jan 2006
That would be a bad assumption once you look at his signature...
All dyno's and variables at the time of Dyno Tuning are different.... You can't compare dyno sheet to dyno sheet unless it is the same EXACT dyno.
Old 03-13-2006, 08:35 AM   #6
Yes, I agree. It is all Cobb Stage II. I just like what chris did with the before & after, that way I am comparing apples to apples.
BTW: Before this Protune, on a different day and on a different Dyno my car (Stg II) made: 300whp/330wtq. So comparing different dyno sheets really can give you false findings.
Old 03-13-2006, 09:40 AM   #7
Car: CGM 05 STI
IWSTI Addict since: Jan 2005
Yeah the Dyno Dynamics they have up there is very conservative. Comparing other dyno's on different days is pretty meaningless. Same car same day before and after gets you a much clearer idea. BTW are you Catted or Cattless?
darkcrystal05 is offline   Reply With Quote
Old 03-13-2006, 09:43 AM   #8
Catted
Old 03-13-2006, 09:58 AM   #9
Car: CGM 05 STI
Cool.
