Go Back   IWSTI.com: Subaru STI Forums > STi Technical Discussion > ECU Tuning & Performance Electronics > Review STi Tuners
Old 09-29-2005, 03:22 PM   #1
Car: Your STi ;)
Fav Mod: Everything
Default 391.3 whp 385.8 wlb-ft SR55 "success" 20.5 psi peak 19.5 psi taper 93 octane
Despite being my least favorite turbo, I was impressed with this SR55 setup. No guarantees against rich stutter with the DR725 FMIC when I take it off the dyno in the morning, but it hadn't been too bad so far.
whp wtq
Here's boost:
wtq bst
we did spray the FMIC and charge pipes with room temp water before the run. AFR's were "perfect" 10.6:1 from peak tq to 5400, then smoothly up to 11.2.
SS
Old 09-29-2005, 07:37 PM   #2
Looks great Scott. I knew you had more in that thing. Is this thing welded or stock?
quickone is offline   Reply With Quote
Old 09-29-2005, 07:59 PM   #3
Car: 06 Ford F150 Lariat
Fav Mod: 4X4
Send a message via AIM to 05impreza
sweet, sounds like it turned out good....
jason
05impreza is offline   Reply With Quote
Old 09-29-2005, 09:04 PM   #4
Scott, if you don't mind my asking, why do you say, "Despite being my least favorite turbo...?"
Old 09-30-2005, 07:46 AM   #5
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
wow, the spool up on that looks great.
Old 09-30-2005, 08:07 AM   #6
I think its a little late hitting... other comparable turbo's spool a bit faster, SZ55 and GT30R come to mind...
focus4 is offline   Reply With Quote
Old 09-30-2005, 12:49 PM   #7
Car: WRB, 2005 STi
nice results. thanks for sharing.
What kind of gas?
Is this the new SR55 with the 27mm wastegate?
keyser_soze is offline   Reply With Quote
Old 09-30-2005, 01:22 PM   #8
Car: Your STi ;)
Fav Mod: Everything
Yep, it's a little laggy. The SR55's seem to be overpriced and normally require more boost to make the same power. I was HIGHLY impressed with this one. We had a number of mid 380 whp and high 360 to 370 wlb-ft pulls, which is pretty typical for near 20 psi on these. I let the engine bay cool and made that 391 and 386... it was on normal old 93 octane.
It is an older SR55, IWG...
SS
Old 09-30-2005, 01:40 PM   #9
OK, lag and price, gotcha. Just curious.
Old 09-30-2005, 02:25 PM   #10
i like how it hits peak torque and then just instantly falls off.
edit- not saying, or even inferring that it's a software issue.
particleeffect is offline   Reply With Quote
Old 10-01-2005, 03:54 PM   #11
Car: 04 UK Spec STI
Fav Mod: F-CON V Pro
When does it hit 1 bar ?
WhiteKnight is offline   Reply With Quote
Old 10-03-2005, 10:02 AM   #12
Wink
Originally Posted by Subaru of Gwinnett
Despite being my least favorite turbo, I was impressed with this SR55 setup. No guarantees against rich stutter with the DR725 FMIC when I take it off the morning, but it hadn't been too bad so far.
whp wtq
Here's boost:
wtq bst
SS
I've been trying to tell everybody this is the best bolt on turbo you can buy, and this comes from Gadiel from Big Valley, if properly tuned. I can not wait to bolt mine on.
mike05sti is offline   Reply With Quote
Old 10-03-2005, 01:31 PM   #13
Car: 05 WRB/Gold
laggy hmmm. 150whp by 300 is similar to a stock sti i think. but correct me if i'm wrong.
Old 10-03-2005, 07:09 PM   #14
Car: 07 SWP/ Gold
Fav Mod: The next one
Trader Rating: (12)
scott,
Which exhaust system did the car have, mainly the down pipe?
thanks
Nick
cleatis is offline   Reply With Quote
Old 10-07-2005, 05:10 AM   #15
Car: Your STi ;)
Fav Mod: Everything
It's all APS....
SS
