Old 09-24-2007, 11:08 PM   #1
Car: Gray 07 WRX STI
Default 07 plug change DIY
I could not find a good example w/pics on this forum. NASIOC had a write up w/pics on an 05 but was completley different than what the 07 looked like.
Anakin STI Walker is offline   Reply With Quote
Old 11-12-2007, 07:50 AM   #2
Car: 07 OBP STI
Fav Mod: Sundays and Boxers
Default Re: 07 plug change DIY
Not sure if no pics is alright. I was just in there recently doing a compression test. Its cake as long as you have a spark plug socket.
The process went something like this:
1) Remove battery (more room)
2) Remove airbox/intake stuff (more room)
3) Remove coil packs (little grey boxes on the side of motor, they are the equivalent to plug wires, I also unclipped it to keep it out of the way)
4) Remove all spark plugs
5)Put new plugs in (gap if necessary)
6)Put everything back together
StylesJim is offline   Reply With Quote
