Old 09-09-2007, 03:00 PM   #1
Car: 05 Subaru Sti
Fav Mod: Defi triple pod guages
Post How to seal a bigger TMIC
Need help just installed an X02 Racing TMIC and the stock Sti splitter rubber boot or gasket is too small how do you build a new one or modify the hoodscoop for better fitment over the bigger TMIC.
Thanks in Advance
Alex
STIFun is offline   Reply With Quote
Old 09-09-2007, 05:51 PM   #2
Car: 05 Subaru Sti
Default Re: How to seal a bigger TMIC
So can anybody give me a hand.
Old 09-10-2007, 11:37 AM   #3
Car: WRB EDM 06 WRX STI
Fav Mod: Aerys 3"
I think fullerton has done something with a garage door rubber seal around his TMIC...but maybe I´m wrong
torquemada is offline   Reply With Quote
Old 09-10-2007, 11:41 AM   #4
abracious
Fav Mod: Track time
yeah- i used a garage door seal on mine. works great:
Old 09-10-2007, 11:42 AM   #5
How did you direct airflow to your larger TMIC?
Old 09-13-2007, 07:10 AM   #6
Car: 05 Subaru Sti
Any thoughts on removing the air splitter completely and those people with the rubber seals has your set up lasted on the car with no melting issues.
Old 09-14-2007, 10:46 AM   #7
Car: 05 Subaru Sti
Thanks everybody for all the great info just finished doing my car with the new rubber seal and it is much better.
Old 09-14-2007, 11:05 AM   #8
Fav Mod: Aerys 3"
what kind of seal?
Old 09-14-2007, 12:16 PM   #9
Fav Mod: TiC AST Coilovers!!!
Trader Rating: (90)
(Using turboXS hyperflow TMIC) I put weatherproofing foam around the IC hole. I stuck it to the underside of the hood because it comes with sticky glue on one side. When the hood is closed it seals down around the IC body but it does not melt. I had to trim the parts of the metal shroud that used to hang down so it would fit.
WC LATHE WERKS is offline   Reply With Quote
Old 09-14-2007, 01:23 PM   #10
abracious
Fav Mod: Track time
Originally Posted by torquemada View Post
what kind of seal?
Most of us are using a garage door seal. $9-15 at you local home improvement store. I attached mine with the "extra heavy duty" 3m double sided tape.
