Old 05-04-2007, 11:04 AM   #1
Default control arm replacement
I had a run in with a curb a while back and it left my caster a bit off on one side, so it looks like I'll be replacing the control arm. From what I know, it should be a pretty simple task, but I thought I'd double check to make sure there aren't any small things (like tourque specs for bolts) that are really important.
If anyone has any info, I'd really appreciate it. Thanks!
KrazyKarl is offline   Reply With Quote
