Old 04-06-2007, 07:17 PM   #1
Car: 07 OBP STi
Default Remove front STi emblem on 07 front grill
Looking on how to remove it, thanks
fatcircles is offline   Reply With Quote
Old 04-11-2007, 08:30 PM   #2
Fav Mod: Custom built TBE FTW!!!
Send a message via AIM to CenCali07STI
Pull the two top clips out of that driver side grill then you can pull both the painted exterior section out and the black mesh grill comes out with it. They may seperate from each other a little when you pull it out but dont worry. You might have to pull hard to mine were not to bad. Then on the back side of the grill there is I believe just to small nuts holding the emblem on. I did not remove mine I just saw it last night when I installed my perrin front license plate delete.
CenCali07STI is offline   Reply With Quote
Old 04-12-2007, 04:23 AM   #3
Car: 07 Subaru Satin Whit
Fav Mod: Protuned STG 2
Send a message via AIM to PCGuRu2K
Seems like a lotta ppl break at least 1 tab when they remove the grill. Any tips on removing them without breaking anything?
PCGuRu2K is offline   Reply With Quote
Old 04-12-2007, 04:44 AM   #4
Car: 06 STi
Are you talking about the little pink sti letters on the side grille? if you are it's a pain to take it off. It's held on by 2 metal locking tabs that bites into the plastic studs on the back of the little emblem. Which basically means that it's easy to push them onto the studs but once they are there it's impossible to get them off.
gte123v is offline   Reply With Quote
Old 04-12-2007, 09:26 AM   #5
Car: 2006 STi
Fav Mod: Protune
Send a message via AIM to Zach STI
Mine came off fine with vise grips.
Zach STI is offline   Reply With Quote
Old 04-12-2007, 10:23 AM   #6
GJM
Send a message via AIM to GJM
mine came off witha pair of clippers and a flat head...
GJM is offline   Reply With Quote
Old 05-11-2007, 04:04 PM   #7
Car: 07 OBP STi
Default Re: Remove front STi emblem on 07 front grill
I just dremeled mine off
