Old 04-02-2007, 10:05 PM   #1
Fav Mod: HKS CARBON TI
Default Downpipe Install
Im interested in doing a downpipe install but im not sure what to do. Can someone do a How-to Install for a downpipe?
Old 04-02-2007, 10:49 PM   #2
Car: 04 subaru sti
Fav Mod: 35r turbo kit
downpipes are rather easy, pop your hood, remove your topmount intercooler, two 12mm bolts hold it on and then the silicone boot to the throttle body. Unbolt the bov from the intercooler, ( i find it easier to do that than to remove it from the recirc line) theres a heatshield covering your stock dp, theres i believe 5 or 6 10mm bolts holding it on. Just lookaround and spot them. soon enough the heatshield will come off. Now you should see the top part of the downpipe. Spray it down with some kind of lubricant so you dont strip or seize a bolt. Theres 2 14mm bolts and 3 14mm nuts that hold the dowpipe to the turbo. If you can get your hands in there, you can undo them all from the top...if not, you'll just undo them from the bottom. once youve done all you can do on the top, go underneath and un bolt it from the midpipe. 2 14mm bolts and nuts hold them together. Unplug your o2 sensor which you will later remove with o2 sensor tool, or a proper sized wrench. There is one more 14mm bolt that holds the downpipe to the tranny crossmember. Take it and give the tab a lil push to get the dp clear. It should come out once thats down and install the new dp in reverse order. Hope that helps ya out. Will
will12345 is offline   Reply With Quote
Old 04-02-2007, 11:07 PM   #3
Car: 08 STi, SSM
scoobymods.com has a good walk through.
anti-seize compound is your friend, PB blaster rocks!
Old 04-02-2007, 11:16 PM   #4
Car: 06 WRB/Gold STI
Fav Mod: No Car Note
Having a breaker bar is a plus too.
YeloFva is online now   Reply With Quote
Old 04-09-2007, 09:49 PM   #5
Car: 07 SWP STi
Fav Mod: Perrin Exhaust
can i get anti-seize from a local auto parts store?
Dragicon is offline   Reply With Quote
Old 04-09-2007, 10:14 PM   #6
Ben
Retired Admin
Car: 2006 Audi S4
Fav Mod: Weight Loss
Send a message via AIM to Ben
I've done the downpipe / turboback exhaust 4 times now without removing the intercooler. You can get the headshield off just fine with a 10mm flat ratchet and the 5 downpipe bolts / nuts off with a 14mm swivel head ratchet / socket. You just need to do the top 2 bolts from above, and the bottom 3 bolts from below.
Ben is offline   Reply With Quote
Old 04-09-2007, 10:27 PM   #7
Car: '06 STI
Fav Mod: air freshener!!!
^^^whaddayouknow, you dont even own a Suby.... (sorry )
Westi, if you know someone that has ever done it, have them help out. On a lift it is a snap. On the ground it is more difficult but easily do-able. Be sure to use a box end (not an open end) wrench for the O2 sensor and get a smooth hook tool to feed the IC hoses back on to their spigots nicely. Also, make sure that your heatshield is on properly or else you'll get the rattles. Other than that its all about basic mechanical common sense.
If you have 10k or less miles, you can prob re-use the gaskets. If not or you are concerned, have some new ones available.
Since you have a Cali '06, it shouldnt be too crusty already (sorry to all you mid west salted road drivers...)
Anti-sieze is available at every parts store and you wont need much, just buy the smallest tube you can. It also works well to put a little on the back of your brake pads (the metal side, not the material side ) to help with brake squeeks.
Dont forget to flash a stg 2 map or go get a nice custom tune. I am really happy with Harman in Torrance.
http://www.harmanmotive.com/index.html
Old 04-09-2007, 10:46 PM   #8
Car: 04 Sti
ha this is funny, i'm installing mine tomorrow. Glad i saw to work from the heat sheild down, that probably saved me a good hour
bigJP is offline   Reply With Quote
Old 04-10-2007, 08:37 AM   #9
Car: 07 SWP STi
Why does the wrench matter on the o2 sensor? And when you mean a box wrench is thst a reference to say a socket wrench or is that the circular section on the back of a wrench?
Also i read about torque requirements for the bolts on the downpipe a few threads down.... what type of torque should i put on the bolts?
Old 04-10-2007, 08:40 AM   #10
Car: 05 Aspen White STI
Fav Mod: Defi Gauges
Send a message via AIM to STI_Mike
it's easy i've done it like 4 times myself
STI_Mike is offline   Reply With Quote
Old 04-15-2007, 07:55 PM   #11
what are the torque specs for the bolts on the downpipe and midpipe?
Old 04-15-2007, 08:55 PM   #12
Fav Mod: I can only choose one?
Send a message via AIM to Stargazer
The Cobb instructions say 26 ft/lbs for the downpipe.
http://www.cobbforums.com/forums/showthread.php?t=32208
Stargazer is offline   Reply With Quote
Old 06-14-2007, 07:05 AM   #13
Car: 07 OBP WRX-STi
Fav Mod: Girl in the backseat
Default Re: Downpipe Install
ALL YOU HAVE TO DO IS UNPLUG THE WIRING HARNESS!!! take 1.7seconds... no need to screw with the intercooler.
TuffStuff is offline   Reply With Quote
Old 07-04-2007, 06:45 PM   #14
Car: 2007 OBP/Gold Wheels
Fav Mod: Prodrive Mudflaps
I had to take the intercooler off because I couldn't get the heatshield out of there with it in. Also, to get at some of the nuts and bolts holding the downpipe onto the turbo, it is almost impossible to get at them with the intercooler on. I went into this install fully prepared to work around the intercooler, and I have no idea how anybody has been able to do this without removing it. The intercooler was a breeze to take off, and somewhat of a pain to put back on. Without an adjustable ratchet and various ratchet extensions, this job can be very difficult. A good thread to start and sticky would be "what tools are needed for a downpipe install?" Once you have the proper tools, the rest is common sense.
Old 07-04-2007, 07:38 PM   #15
i did it without taking off the intercooler
