Old 09-21-2007, 07:17 PM   #16
Default Re: Downpipe Install
Originally Posted by will12345 View Post
downpipes are rather easy, pop your hood, remove your topmount intercooler, two 12mm bolts hold it on and then the silicone boot to the throttle body. Unbolt the bov from the intercooler, ( i find it easier to do that than to remove it from the recirc line) theres a heatshield covering your stock dp, theres i believe 5 or 6 10mm bolts holding it on. Just lookaround and spot them. soon enough the heatshield will come off. Now you should see the top part of the downpipe. Spray it down with some kind of lubricant so you dont strip or seize a bolt. Theres 2 14mm bolts and 3 14mm nuts that hold the dowpipe to the turbo. If you can get your hands in there, you can undo them all from the top...if not, you'll just undo them from the bottom. once youve done all you can do on the top, go underneath and un bolt it from the midpipe. 2 14mm bolts and nuts hold them together. Unplug your o2 sensor which you will later remove with o2 sensor tool, or a proper sized wrench. There is one more 14mm bolt that holds the downpipe to the tranny crossmember. Take it and give the tab a lil push to get the dp clear. It should come out once thats down and install the new dp in reverse order. Hope that helps ya out. Will
These are great instructions! I replaced my downpipe and exhaust in about 4 hours without taking the intercooler off following these.
Thanks alot, this is all you need
-Jerry
sanscritt is offline   Reply With Quote
Old 09-21-2007, 07:40 PM   #17
Car: 1998 Impreza GF8
Send a message via MSN to RFFG
Gets easier the more you do it...
I've done mine 3 times already
RFFG is offline   Reply With Quote
Old 09-21-2007, 07:48 PM   #18
Fav Mod: Zzyzx Coilovers
No need to remove the IC, that's just extra work. You WILL need a breaker bar, or as we call it, a "B**** Bar," and some anti-seize would help. Don't be surprised if you snap a bolt, I did. You may wan't to buy an extra one before hand just in case. Make sure you use the proper gaskets and/or Permatex ULTRA COPPER Hi-Temp RTV Silicone Gasket if needed. That's my tip for the day.
JD_STI is online now   Reply With Quote
Old 09-21-2007, 09:55 PM   #19
Bronze SEMA 2007 Sponsor
^^ True, I broke 1 bolt myself so yeah even if you dont break any its always wise to keep spares.
STi_4_Daddy is online now   Reply With Quote
Old 09-21-2007, 09:59 PM   #20
dex
Car: 07 CGM STi
Fav Mod: Stage 2
Send a message via AIM to dex
i also broke one on the turbo. :X anyways make sure u got the right stuff needed that heatshield is going to be a b*tch
dex is offline   Reply With Quote
Old 09-21-2007, 11:45 PM   #21
And use 6 point sockets not 12!
Old 09-22-2007, 11:00 AM   #22
yeah that. If you don't have an angle grinder to cut the heat shield, you can get by with a metal hand saw, tin snips, and a file.
Old 02-03-2008, 02:13 PM   #23
Car: 06 Subaru WRX STI
Fav Mod: Headlight Adjustment
Send a message via ICQ to MasterColin Send a message via AIM to MasterColin
Bringing this one back from the dead...
I want to install my DP and a Heat Shield. Do I need to remove the IC to install a Cobb Heat Shield?
MasterColin is offline   Reply With Quote
Old 02-03-2008, 02:30 PM   #24
Car: 2007 OBP/Gold Wheels
Fav Mod: Prodrive Mudflaps
I originally was not going to remove the intercooler, but after I removed all the bolts on the stock heat shield, I couldn't pull it out without removing the intercooler. I think it makes the install of the DP much easier with the IC off.
Old 02-03-2008, 02:36 PM   #25
Car: 06 Subaru imprezaSTi
Fav Mod: Prodrive
I didn't but it was a pain in the ass to get the cobb heat shield on just putting the heat shield on took almost a half hour and it's only 3 bolts
steelgraySTi06 is offline   Reply With Quote
Old 02-03-2008, 03:40 PM   #26
Yeah I was thinking about taking the stocker off. Taking the car in to get the DP put on (I don't want to have to try to do it my self with out a lift or ramps of any kind in Wi weather) and then after getting the dp on, installing the shield. Is that possible?
Old 02-03-2008, 04:13 PM   #27
I think steelgray answered your question.
If you can't do it with the IC on, then just take it off.
Old 05-06-2008, 06:01 PM   #28
Car: 05 WRB Sti
Fav Mod: Stage 2
sorry for bringing this thread back....im currently installing a turboxs downpipe on my05 took the intercooler off, then the top half of the heat shield and i had to also take the bottom half as well? my dp wouldnt fit without taking it off. is that correct? not sure whether or not the bottom half must be back on
ezsleeper is offline   Reply With Quote
Old 05-06-2008, 07:07 PM   #29
I have no experience with that DP, but if you had to remove the bottom heat shield I would look into possibly wrapping your DP or finding out if there is one made to fit with the turboxs DP.
Old 05-06-2008, 07:26 PM   #30
Car: 05 WRB Sti
Fav Mod: Stage 2
its wrapped, just wondering if anyone with the same dp put back their lower heatshield. is it necessary to have the bottom bracket? im keeping the stock heatshield and going with an aftermarket one that fits.
