Old 12-07-2006, 06:52 AM   #1
Car: 2004 sti
Fav Mod: coliover
Send a message via AIM to PPERICFE
Default how to remove head light from a 2004 sti
i try to change the parking light couldnt do it any body have some info
PPERICFE is offline   Reply With Quote
Old 12-07-2006, 08:37 AM   #2
Car: 06 CGM STi
Fav Mod: brake dust generators
Send a message via AIM to osbjmg
I spent 5 minutes looking at my 06, couldn't find anything easily. I need to do some research on this as well...
osbjmg is offline   Reply With Quote
Old 12-07-2006, 10:10 AM   #3
Trader Rating: (25)
Send a message via AIM to GarageSpec.com
the 04 parking light bulb can be access without taking off the headlight.
The 06 i believe requires you to remove the headlight housing.
06 is complicated because you will need to remove the entire 3 piece center grill held in by clips. Then you unbolt 2 bolts on top of the headlight and 1 on a bracket behind the grill.
Then PULL
GarageSpec.com is offline   Reply With Quote
