Old 12-05-2006, 01:16 PM   #1
Car: 04 WRB WRX STi
Send a message via AIM to cloSTi
Default Oil gauges: Tee em or sandwich em?
In regards to oil pressure and oil temp gauges, what is your preferred method of installation? I have heard that oil pressure should be sandwich adapted and oil temp should be tee'd. Any experts please chime in, thank you!
cloSTi is offline   Reply With Quote
Old 12-05-2006, 01:23 PM   #2
Ben
Retired Admin
Car: 2006 Audi S4
Fav Mod: Weight Loss
Send a message via AIM to Ben
I just used the greddy sandwich adapater, which has 2 tap-in points, or whatever you want to call them. I've done this on atleast 5 different cars with no problems.
Ben is offline   Reply With Quote
Old 12-05-2006, 01:58 PM   #3
Or there are 2 galley plugs on top of the block (which is what I used). One for pressure, one for temp. I don't think there is a right or wrong way.
klaymon is offline   Reply With Quote
Old 12-05-2006, 02:30 PM   #4
Fav Mod: BOV and MBC
where are these plugs and how do you plug into them, drilling required or is there a bolt that gets removed?
Old 12-05-2006, 02:33 PM   #5
Car: 06 Subaru WRX STI
Fav Mod: air freshener (mmm...squash)
http://www.scoobymods.com/forums/showthread.php?t=5513
halfbr3d is offline   Reply With Quote
Old 12-05-2006, 02:37 PM   #6
Originally Posted by halfbr3d
Thanx for the quick responce!
Old 12-08-2006, 09:40 AM   #7
Car: 04 WRB WRX STi
Thanks for all the great info guys!
Old 12-08-2006, 08:43 PM   #8
If in doubt, flat out
Trader Rating: (23)
any one know where to get the T so you can connect both oem and the aftermarket pressure sensor in one galley?
Old 12-08-2006, 08:50 PM   #9
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
I installed my oil temp and pressure sensors in the galley plugs. The temp sensor went under the intercooler plug and the pressure sensor replaced the factory dummy-light sensor (which resides under the alternator.) Removing the factory pressure sensor doesn't cause any ill effects; no warning lights etc.
I went with the galley plugs based on suggestions from this forum and NASIOC. Apparently using the galley plugs tends to give you better accuracy and sensitivity to changes (pressure drops/temp spikes etc.)
Old 12-09-2006, 07:24 AM   #10
Car: 05 WRB STi
Fav Mod: PWT Points
sweetness - now i just need gauges to install haha
Old 12-10-2006, 02:59 PM   #11
Car: 07 WRX STi
So out of curiosity (and subscription) What is more acurate? the galley or the sandwich? Any good vendors for the sandwich? It sounds like it might be a little bit easier because of NTP vs BTP.
Ooie is offline   Reply With Quote
Old 12-10-2006, 05:03 PM   #12
I have a oil galley plug that i never used, and now that my STi is sold, ill give it to you if you want it for free. PM me
electricevo is offline   Reply With Quote
Old 12-11-2006, 12:11 AM   #13
Banned
Fav Mod: knowledge
Send a message via AIM to Guest_1u53r
The only "wrong" way to do it is to use a T or remote-mount for an Oil temperature sender. T's and remote-mounts work great for pressure, but if you try to do that for temperature, the reading will be completely wrong.
Guest_1u53r is offline   Reply With Quote
