Old 12-03-2006, 06:18 AM   #1
Default 2006 sti day lights.......
Hey just wondering how to remove the headlights on order to get to that lill day light bulb??????????
I tryed last nite couldn't do it...
I want those things gone, also why cant you shut off the HID on an 06 STI????
Eggbread is offline   Reply With Quote
Old 12-03-2006, 06:30 AM   #2
Car: 06 STi
Search the how to forum for 'DRL'. The thread on how to turn them off is in there. It is really easy, just take the glove box off and unplug a 10 pin connector.
jimmystmartin is offline   Reply With Quote
Old 12-03-2006, 08:21 AM   #3
thanx bro
Old 12-03-2006, 09:21 AM   #4
went and looked at those pics... did the the same thing as everyone else but i did NOT work..!!!!!!!! im 100% positive that i disconnected the right one....car wont even start.....
Old 12-03-2006, 09:47 AM   #5
never mind i got it to work....its just that i tought those lill yellow bulb was conciderd as day light not the LOw beam HID....now i can turn the HID on and off whenever i want to, but those lill bulbs are still buggin da hittttt out of me....im about to clip a wire cuz i can get to those lill bulbs, i tryed taking the headlights off to get to it, but did not know how to.!!!!!!! help
Old 12-03-2006, 10:25 AM   #6
Car: 06 STi
Fav Mod: TBE, AP, Protune
Check and make sure you don't have your parking lights on, above steering.
If you unpluged the right connection, none of the lights should be on, unless you turn lights on.
MadRussian is offline   Reply With Quote
Old 12-03-2006, 10:33 AM   #7
ther are not on unless i turn them on, i unpluged the right one, but when i do turn them on i want that lill halogen bulb off, its right above the halogen high beam....
Old 12-03-2006, 11:33 AM   #8
Car: 06 STI...FP Green
So you don't want your parking lights to ever come on?
Chris is offline   Reply With Quote
Old 12-03-2006, 12:11 PM   #9
yup dont want them at all....especially that lill ****ty bulb above the high beam...
Old 12-03-2006, 12:13 PM   #10
but the orange parking lights dont bother me as much as that lill bulb, how can i just unplug it??? Cuz i really cant reach it...How do you remove the headlights??????
Old 12-10-2006, 12:29 PM   #11
Car: 06 WRX TR
Fav Mod: Recaro SSL
Send a message via AIM to aboothman Send a message via MSN to aboothman
ya know, I unplugged the DRL plug under my glovebox and tested it....didn't work. I rechecked on the scoobymods instruction thread, tried again, and still didn't work.
Then I moved the car around to the front of my house, and it worked!! Maybe it has something to do with moving the car. I dunno. Try unplugging it and moving the car a few feet.
Also, mine only come on when I have the headlight switch in the middle selection, or when I use them as parking lights. They are off any other time.
*edit Oh, if you search around, there is a way to disable them from the engine bay. If you disable them there AND where the relay plugs under the dash, that should remove them completely. If you search for DRL of day running lights on here or NASIOC you should find it.
aboothman is offline   Reply With Quote
Old 12-10-2006, 02:19 PM   #12
Car: 06 WRB STi
He's talking about the little bulb in the headlight that turns on with the low/high beams (it's between the low and high beem). That same bulb also turns on when you flip the parking light switch.
webcrawlr is offline   Reply With Quote
Old 07-23-2007, 05:13 AM   #13
Car: 06 WRB STI
Fav Mod: Volk Racing RE30 (Diamond Black)
Default Re: 2006 sti day lights.......
Unplug 10 pin. No more DRL.
TheHammer is offline   Reply With Quote
