Old 04-03-2008, 09:43 AM   #31
Car: '06 steel grey, son.
Fav Mod: learning how to drive stock first
Default Re: Help: Coolant flush /antifreeze change
Originally Posted by A1337STI View Post
I did a flush at the end of summer but only refilled the radiator & plastic reservoir , forgetting about the Metal turbo reservoir.
this is something i didn't see mentioned in this thread, nor in the fsm.... is the turbo coolant res supposed to be filled up at this time as well, or will it just work its way there on its own?
nonissan is offline   Reply With Quote
Old 07-03-2008, 10:11 AM   #32
Car: Blue 07 WRX STI
Fav Mod: Soap
FYI...this might not be exactly what you are looking for, but I just got this done.
DIY Engine Coolant Change
STI Sibb is offline   Reply With Quote
Old 07-03-2008, 10:15 AM   #33
Car: 05' AW WRX STi
Fav Mod: Passport 8500 X50
the turbo coolant system isn't a independent coolant system, it uses the same coolant system as the car, so yea it "works" its way around.
sujak is online now   Reply With Quote
