Old 01-31-2008, 05:40 PM   #16
Car: 04 JBP STi
Fav Mod: Me Driving The Car
Default Re: Help: Coolant flush /antifreeze change
+1 on the DIY thread!! with pictures pleeaaaasee.. LOL
xAxAx is offline   Reply With Quote
Old 01-31-2008, 05:55 PM   #17
Fav Mod: CAR LIFT & Protune!
this is WAAAY easy to do...
1. on the bottom of the radiator, toward the driver side, little valve you twist with finger and let old coolant drain. (MAKE SURE ENGINE IS COLD).
2. Close drain fill with distilled water (through radiator cap).
3. run engine for 30 seconds.
4. repeat step 1.
5. close valve.
6. fill 50/50 coolant and distilled water.
7. LET ENGINE RUN WITH CAP OFF, this is safe becuase pressure wont build up...
8. stand in the engine bay and add coolant into the radiator (you will see the level go down as the air bubbles in the system are filled with liquid).
9. let it run for 5 mins watching and make sure your coolant resivour(SP?) is full.
10. recap radiator, and test drive. check after engine cools.
i am a person who is very worried about things going wrong. This is the safest way to do this!!
MAKE SURE YOU BUY THE GENUINE SUBARU COOLANT, ALL OTHERS have been known to eat gaskets away and void warranty
Old 01-31-2008, 05:57 PM   #18
Originally Posted by blueman05 View Post
now i was at the dealership today and they said when flushing the system to remove the thermostat or it could get damaged???
they are telling you this so you say "OMG i dont know how to do that!!" and you will let them do it for like 500 bucks. ever heard the quote "all good salesmen go to hell." hes making a shady suggestion.
Old 01-31-2008, 06:22 PM   #19
Car: 04 JBP STi
so am I! ... but where do i get the GENUINE SUBARU COOLANT?
Old 02-01-2008, 08:00 AM   #20
Car: wrb 2005 STi
Fav Mod: FP GREEN
Send a message via AIM to blueman05
looks hard to get to the drain plug and from what i can see its on the passanger side.... what about draining from lower radiator hose? i cant take the thermostat out and run a hose through the 2 fill up points>???
blueman05 is offline   Reply With Quote
Old 02-01-2008, 09:01 AM   #21
Fav Mod: FYI, I'm a dude
the subie dealer. make sure you get a bottle of the coolant conditioner/additive too.
Old 02-01-2008, 10:02 AM   #22
Car: '06 steel grey, son.
Fav Mod: learning how to drive stock first
so are people doing water + subie coolant + additive + watter wetter? seems like a lot of fluids to mix together...
nonissan is offline   Reply With Quote
Old 02-01-2008, 10:35 AM   #23
Car: wrb 2005 STi
Fav Mod: FP GREEN
doing this tomorrow more as mush help as possible here guys... i was gonna drain from lower radiator hose then fill system with distilled water let run to operating temp then let cool drain again then fill fill 50/50 mix and additive confused about the next part as far as burping the system leaving the radiator cap on or off etc... want to do a complete flush simple as possible.....
Old 02-02-2008, 01:12 PM   #24
Car: wrb 2005 STi
Fav Mod: FP GREEN
just finished the flush and came out good from what i can see.... im gonna keep an eye on the coolant level to make sure because i didnt get all 2 gallons in. i removed the lower radiator hose and thermostat let it all drain out then ran a hose through the radiator and upper coolant housing by the turbo until only clear fluid came out. put it all back together filled the radiator, overflow tank, and upper housing with 50/50 mix subaru coolant and distilled water from cvs. also added the coolant conditioner additive from subaru. turned the car on let it run with heat full blast on defrost until fans came on then shut down and i have to double check levels once cool. didnt over heat once temp gauge stayed right around the middle little below....
Old 02-02-2008, 01:13 PM   #25
Car: wrb 2005 STi
Fav Mod: FP GREEN
also left upper housing coolant cap off until air bubbled out and started to over flow then recapped...
Old 03-10-2008, 07:02 PM   #26
Car: 05 WRB STi
Fav Mod: The car
Send a message via AIM to B00stedreams
Sorry to bring this thread back, but about how much coolant/water mix did you guys use to get the system full?
Edit: Found the answer to my own question
B00stedreams is offline   Reply With Quote
Old 03-10-2008, 07:46 PM   #27
Car: wrb 2005 STi
Fav Mod: FP GREEN
about 2 gALLONS
Old 03-14-2008, 09:24 PM   #28
Car: 05 WRB w/Gold
Has anyone ever had intermittent over heating after a DIY coolant flush?
I did a flush at the end of summer but only refilled the radiator & plastic reservoir , forgetting about the Metal turbo reservoir. The car was fine for for a day or so, then it overfilled the plastic (over flow / reservoir) by a lot, then it over heated.
after that i took it to a meinkie for a coolant flush. it hasn't spit any coolant out, although the fills the plastic tank to the top. Before the engine temp gauge would always read nearly at the bottom of the normal range. Now it will often rise up to the top of the normal, Usually while on uphills, but sometimes while on a flat. It ran too cold one morning . Also while coasting down a long long hill in nuetral it ran normal, then ran near the top of the normal range , then went back down to normal.
could i have messed up the thermostat somehow? I've tried taking the car into the subaru dealership as i'm under warenty still, but they haven't been able to duplicate the problem. the car does not run too hot Every day. but almost every day, but i also can't duplicate the issue upon demand. sometimes i can drive up a long hill @ 2500 or 5000 with no running hot, other times it runs hot no matter what.
I'm thinking i'm going to replace my thermostat myself just try something (plus an other coolant flush) :| Chitty
A1337STI is offline   Reply With Quote
Old 04-01-2008, 09:42 PM   #29
Car: OBP 06 STI
Ive seen other people say this but never understood what you are exactly doing. Could someone explain it better?
And according to that document subaru coolant is already a 50/50 mix, so do you put that straight in or use a 50/50 of that mix with water (which would mean the coolant percentage is now 25%) ?
jsnuff1 is online now   Reply With Quote
Old 04-02-2008, 05:02 AM   #30
Car: wrb 2005 STi
Fav Mod: FP GREEN
coolant i bought from subaru wasnt premixed. i bought diluted water to mis it. i removed my lower radiator hose and thermostat then used a garden hose and ran water til through radiator til it was clear and through the tank by the turbo until it was clear running out the bottom.
