Old 11-12-2006, 09:52 AM   #1
Car: Black 06 STi
Fav Mod: Radar Detector
Default PE 850 Fuel Injector Install
Anyone with PE 850s! When you pull the wiring harness off the stock fuel injectors they don't fit the PE 850's. So, when you pull the wires out of the old harness, does it matter how you wire them into the new injectors???
cosprings is offline   Reply With Quote
Old 11-12-2006, 10:30 AM   #2
Car: 2006 STi
This is the post I referenced to when installing my fuel injectors.
DIY 720cc JECS Injector Install
Good luck
NterceptR is offline   Reply With Quote
Old 11-12-2006, 01:45 PM   #3
Fav Mod: Carlabs X-brace & RPM brace
So you don't need clips. You just take out the orange piece right?
hoffit is offline   Reply With Quote
Old 11-12-2006, 05:20 PM   #4
Car: 2004 STi
Fav Mod: FP Green
Send a message via AIM to MauroMotorsports
You'll need to use the supplied clips and remove the stock clips from your existing wiring harness. The OEM clips will NOT work with the PE 850's. It's a simple swap, but take your time not to break any of the PE clips. They're a bit delicate.
MauroMotorsports is offline   Reply With Quote
Old 11-12-2006, 09:25 PM   #5
Car: Black 06 STi
Well, I wired them the same way the stock one's were set up. That is, when looking at the injector from the side with the side feed facing you, I put red on the RIGHT connector. Let's hope it works when I get this thing put back together! Thanks NterceptR for the link reference.
