Old 11-02-2006, 06:16 AM   #1
Fav Mod: Starving my STI
Trader Rating: (12)
Default Torque Specs thread
Well since I don't have the service manual, I'm always searching for torque specs... so I thought I would start a thread where people can post their torque spec requests and others can respond.
I'll start it off.
1. Rear caliper bolts for 05 STI.
2. Front lower strut bolt (the one that blocks the upper front caliper bolt from coming out).
Old 11-02-2006, 08:18 AM   #2
Car: 05, Subaru Impreza W
It appears to be 47.9 ft/lbs for the caliper bolts and 129 ft/lbs for the front lower strut bolt.
BlueGold is offline   Reply With Quote
Old 11-02-2006, 08:25 AM   #3
Car: 06 Evo IX SE
This thread is a great idea!!!
06stiman is offline   Reply With Quote
Old 11-03-2006, 07:06 AM   #4
Fav Mod: Whiteline Suspension
headers to up pipe
headers to engine
up pipe to turbo
downpipe to turbo
Thanks!
cbdSTi is offline   Reply With Quote
Old 11-03-2006, 07:21 AM   #5
Trader Rating: (12)
Originally Posted by cbdSTi
headers to up pipe
headers to engine
up pipe to turbo
downpipe to turbo
Thanks!
They are all supposed to be 28 ftlbs, and some people have recommended an even 30 ftlbs, but you know what, I tried 28, 30, and 35... and I would recommend 35... the reason being, if u do 30, it MAY come loose and u have to retorque... I actually had a DP nut come off when I torqued to 30ftlbs... not good... and some of those bolts cannot be accesed without other stuff coming out... so just do 35... contrary to what some have said, it is NOT too tight and will NOT cause a leak because it's 5 ftlbs tighter. Do it in stages... I recommend 20, 25, 30, 35.
A lot of the bolts require an extension to get to, so 35 is more like 33 anyways... if you use the same extension to the bolts that don't need it, it will give you the most even torque. I recommend using the same extension for each "batch" of bolts that connect the same 2 parts.
Old 11-03-2006, 05:47 PM   #6
Car: 06 OBP STi
Default Torque specs for you suspension!
Hope this helps some of you guys!
http://www.clubwrx.net/forums/showthread.php?t=80548
-Ryan
r12rex is offline   Reply With Quote
Old 11-03-2006, 06:42 PM   #7
Car: 05 CGM STI on 57F br
Fav Mod: stage 2
Originally Posted by BlueGold
It appears to be 47.9 ft/lbs for the caliper bolts and 129 ft/lbs for the lower strut bolt.
Rears are 140 ft lbs I believe while the fronts are 129.
Old 11-03-2006, 06:48 PM   #8
Actually...the rears are 145 ft lbs...but my response was for the fronts as that was what the OP was asking about.
Any suggestion on torque specs for camber plates?? Like RCE plates for example?? I was going to use the stock top hat torque specs but will that work for the two bolts used for adjusting the camber??
Old 11-03-2006, 07:24 PM   #9
2 in the Pink, 1 in the..
Car: Slow POS
Fav Mod: Slow Car FTL
Send a message via AIM to SNE2040
For my DP, i just tightened it until i couldn't anymore. 2 months later, No problems yet...
SNE2040 is offline   Reply With Quote
Old 11-03-2006, 07:36 PM   #10
Car: 06 STI
Yeah, after being a tech for 13+ years I kinda got this calibrated elbow/wrist thing going. Haha
highwayman is offline   Reply With Quote
Old 11-03-2006, 10:51 PM   #11
Trader Rating: (12)
haha... well, some guy on here torqued them to like 70 ftlb which is almost TRIPLE the spec... lol... the most important thing is to make it EVEN among the bolts... whether it's 30, 35, or lol 70.
Old 11-22-2006, 05:39 PM   #12
Banned
Fav Mod: knowledge
Send a message via AIM to Guest_1u53r
Anorexic, I'm moving this to the requests section for now. If you want it to gain full "howto" status, you need to update the first post with all the information that has been submitted.
Guest_1u53r is offline   Reply With Quote
Old 02-15-2008, 01:29 PM   #13
Fav Mod: AP
Default Re: Torque Specs thread
Anybody got the torque specs for the rear diff front mount points and the rear diff case bolts? I'm mounting the prodrive diff cover and have no idea what the correct specs are. Thanks
