Old 04-07-2008, 03:17 AM   #31
Moderator & ECU Tech
Fav Mod: mo boostaz
Default Re: Header and up pipe install
I assume that people should notch the front sheetmetal for the MadDad headers too? I can see that there was some contact with your header and the header wrap is fraying.
t
Old 04-07-2008, 05:46 AM   #32
Fav Mod: The Newest One!
t
You know, I was so tired last night I didnt even catch that. It must have happened on my test run. Guess I am going back under today to work that out. Thanks for the heads up.
On that note, I had to notch the subframe near the collector. Otherwise I couldnt get them on as there wasnt enough clearance.
Old 04-07-2008, 06:55 AM   #33
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
t
Yea the MadDad headers need to have some of the subframe bent/grinded down. Rich @ MadDad has mentioned this a lot in the past on NASIOC.
This seems to be an STi only issue (or maybe a 2.5L engine only issue) since I think the 2.0L WRX can be installed without modding the subframe at all from old posts I vaguely remember when MadDad first came out with these.
I just used a big pair of plumbing pliers to bend the subframe out of the way and it worked well for me for the short time I had those headers installed on my car.
Old 04-10-2008, 01:55 PM   #34
I used a crescent wrench and bent the lip. Ill wait until my next install day to cut if off completely.
Old 04-10-2008, 07:41 PM   #35
Car: 05 Aspen White STi
Fav Mod: 04 WRX -> 05 STi
For you guys that have the Maddad headers/up-pipe, are you guys on your stock sub-frame?
I just ordered some ceramic coated header/up-pipe and I have the do-luck sub-frame. I'm hoping there would be no interferance with the frame. I'll see when I get the parts in May since they're back-ordered.
Kinda OT: I have some group-n engine mounts and kartboy pitch mount that I need to install. Would you guys suggest that I wait for the headers/up-pipe to come in and do them all at once? Since I'm installing the ACPT CF drive shaft tomorrow morning, I figure I do the mounts as well, but I don't want to do things twice if I have to lift the motor.
Jelphree is offline   Reply With Quote
