Old 09-26-2006, 08:51 PM   #1
Car: 05 Subaru WRX STi
Fav Mod: track days
Send a message via AIM to cuzitsmyusofwtvr
Default Need Help - RCE camber plates
Hey,
Got a question about installing the plates, perhaps those of you that are running these can chime in.
I installed the camberplates but for some reason I cannot max out the negative camber. It feels as if it knocks against something when moving it over and will not go any further. I am currently running sti pink springs along with the plates. I have yet to get an allignment with this new set up. At first, I thought I might have installed the spring hat facing the wrong direction, but I checked and they appear to be facing the correct direction. Is it just that I cannot get full adjustability with this particular set up or is something else wrong? I have included a picture to explain what I am talking about.
thanks,
spencer
cuzitsmyusofwtvr is offline   Reply With Quote
Old 09-26-2006, 09:06 PM   #2
OEM struts will not allow you to much more than -2deg. There is nothing wrong with the plates/springs or car.
Enchanter is offline   Reply With Quote
Old 09-26-2006, 09:46 PM   #3
Banned
Fav Mod: knowledge
Send a message via AIM to Guest_1u53r
The spring tophat will hit the base of the plate. When using most coilovers with a smaller tophat, you would get the full slot adjustment.
Guest_1u53r is offline   Reply With Quote
Old 09-27-2006, 05:51 AM   #4
Fav Mod: track days
I was thinking that this was the case, but I just wanted to make sure before I went to get an allignment.
thanks,
spencer
Old 09-27-2006, 05:53 AM   #5
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Yup....What Nick said. I can only run -2.1. Thats after a 'minute' grinding sesh.
Old 09-27-2006, 05:56 AM   #6
Enginerd
Fav Mod: Tuning
If you do get contact while drriving, it sucks. It causes pretty bad memory steer and I think, when you turn the wheel, the lower strut and spring turn in the tophat instead of the top hat pivoting in the camber plate.
