Old 09-20-2006, 08:57 PM   #1
Car: WRB 04 STi
Fav Mod: SNOW TIRES!!!
Question Crossmember install**help!**
I am trying to install a new crossmember, but I can't figure out how to disconnect the steering rack, can anyone help me?
I know that I have to disconnect the universal joint, but I can't get to it, and I don't know what else needs to be done.
Any help or advise would be excellent!
(lifting the engine will be the easy part!)
sigepsti is offline   Reply With Quote
Old 09-21-2006, 06:16 PM   #2
Fav Mod: Whiteline sways, ohlins coils, cusco motor mounts
There is a bolt on the upper part of the u-joint, the part that slides onto the steering column output. Its a tight squeeze but you can unbolt it and slide it out (if I remember correctly) then the ujoint will slide right off the shaft. You need to unbolt the rack so you can pull the joint off the shaft though.
neal0124 is offline   Reply With Quote
