Old 09-17-2006, 11:39 PM   #1
Car: 05 Subaru WRX STi
Fav Mod: Pioneer AVIC-D1 with Ipod/XM
Send a message via AIM to PSJoe96 Send a message via Yahoo to PSJoe96
Default How do I return ECU to stock?
I had my 05 reflashed at PDX tuning with the ECUTEK stage 1 reflash and between horrible gas mileage (14-18 mpg) and running the risk of having my 100k extended warranty voided id rather just return the ecu to stock. How do I go about doing this?
PSJoe96 is offline   Reply With Quote
Old 09-18-2006, 05:37 AM   #2
Car: Slow 05 STi
Fav Mod: Loping Idle
Since you have an 05 you have two options: 1st send it back to PDX and have them reflash it back to stock mapping and lose your license and what you paid for. 2nd trade/sell to another 05 owner trick here being the immobilizer which you must have switched at a dealership then you will be able to trade ecu's so most likely you will need to sell locally unless you can wait out shipping your ecu and etc.
crystal_Imprezav is online now   Reply With Quote
Old 09-18-2006, 09:23 AM   #3
Thanks, I guess my next question is how do I go about taking the ecu out of my car?
Old 09-18-2006, 09:27 AM   #4
Car: Slow 05 STi
One plastic screw retainer at the kick panel- remove and pull up door trim/kick panel. One more plastic screw retainer holding carpet in place, remove it and pull carpet back. Then you will see a metal plate covering the ecu, there are I believe 4 or 5 bolts (10mm or 12mm) holding it in place, remove the plate, unplug the ecu, remove the remaining bolts holding ecu in place.
