Old 09-15-2006, 06:58 AM   #1
Car: 04 PSM STi
Fav Mod: Stage 2 parts
Default UTEC - Map / Clutch Switch Install
Does anyone have instructions on how-to install the clutch switch portion of the UTEC map selector? The TXS instructions don't give you the specifics. It appears that there are two switches on the STi clutch bracket. A blue one and a black one. Looking at the size of the pins on the black one, I doubt it is this one but all my attempts to on the blue switch have failed and don't produce the desired results.
I have confirmed that launch control is setup on the UTEC and that the map switch is controlling the selection properly.
Any guidance on this would be greatly appreciated.
Edit - I have it working. You have to give it a few seconds to kick in and don't be afraid to give it gas. You need to disconnect the blue harness from the switch, connect the fly leads from the map switch harness to the blue switch on the clutch pedal bracket and then use the jumper wire on the original blue wiring harness to close the circuit to avoid a flashing cruise light.
John
ScoreBo is offline   Reply With Quote
