Closed Thread
Old 09-04-2006, 02:53 PM   #1
Car: 06 STI SGM
Fav Mod: seatbelts
Send a message via MSN to boost_happy
Default Rear Strut Nut hard to get off? HELP!!
I'm in the middle of doing a spring job with some prodrive's and I can't get the top nut broken off the Allen screw of the rear strut. I don't want to strip it with my impact gun and I tried about everything I could think of.... Including a 17mm with 6mm allen wrench combo. Is there anything else I could try? Please help. Thanks in advance.
boost_happy is offline
Old 09-04-2006, 02:55 PM   #2
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Just break it loose with the impact gun.
flatthump is offline
Old 09-04-2006, 02:59 PM   #3
Car: 06 STI SGM
Fav Mod: seatbelts
I have an impact gun rated at only 90 psi, it doesen't have enough marbles to break that sucka off, how far can I up the psi on my compressor if its rated at 90psi??? Thanks for the reply.
Old 09-04-2006, 03:01 PM   #4
You'll be more likely to strip a bolt using hand tools over pneumatics because of the fact that an impact gun will shock the bolt free quickly (and effortlessly). Before you go any further, i recommend you soak the bolt in PB blaster, In Force, or any equivalent.
Good Luck
electricevo is offline
Old 09-04-2006, 03:16 PM   #5
Car: 06 STI SGM
Fav Mod: seatbelts
With that advice its currently soaking in PB. I was affraid to use the PB because I didn't want to get it on the strut at all, but I guess it can be cleaned off if it does get on there. We'll see, any other advice. Thanks.
Old 09-04-2006, 03:18 PM   #6
Enginerd
Fav Mod: Tuning
That nut shouldn't be at 90 ft/lbs if I remember correctly. Moree likee e50 something. Ill go look it up...Hold on.
Closed Thread
