Old 08-31-2006, 07:46 AM   #16
Fav Mod: Cobb PROTUNE
Send a message via AIM to Meridock
Wink
Originally Posted by spazegun2213
I have had my headers in an out in less that an hour (but then again, i have done it a few times).
hope this helps.
I may tap you on the shoulder to help me with a EGT probe install as discussed previous.
Meridock is offline   Reply With Quote
Old 08-31-2006, 07:51 AM   #17
Poor Speed Racer
Car: 96 328
Fav Mod: Race Car!
no pun intended
sure, anytime steve.
Old 08-31-2006, 08:59 AM   #18
Muller Chevrolet
Fav Mod: a new 08 STi
Originally Posted by blackbeast06
quick ques ... im trying to remove the O2 sensor, however, a)there is little room to work as all of you know and b) when i get my hand around the sensor, there is nothing that resembles a bolt that i can either get a wrench around or use the O2 socket for removal ... do i need to use a vise grip for this?
did you take off the little piece of plastic in the wheel well?...this allows you to get in better between the frame and plastic.
loosen it, then get your hand in there and turn it but it's tricky because the wire makes the sensor spin the opposite way you're turning it.
don't use any tool but an 02 socket remover with an extension on it.
Old 08-31-2006, 09:02 AM   #19
Muller Chevrolet
the upper bolt on the intermediate pipe to right manifold, i tried 3 different type of extensions and i cant get enough access to bolt ... any suggestions????
how can you not get to it? i got mine off pretty easily...i used a big ole socket wrench with whatever size extension to break it loose...after that it was easy..you took off all the heat shielding right?
Old 10-31-2007, 10:20 AM   #20
Default Re: How To Install Headers???
Are the bolts connecting the headers generally rusty( like needing to be blow torched) or do they just come off fairly easily with some force
deathskrye is offline   Reply With Quote
