Old 08-27-2006, 07:02 PM   #1
Car: 2005 Subaru WRX STi
Send a message via AIM to Mochenmat
Default DP install
i was thinkin about buying a dP so i can go stage II but i was wondering if its hard to install? is it just un bolt and slide in/out ? also im in CA soo would it be worth it to pay the extra cash to get the catted one or what?
Mochenmat is offline   Reply With Quote
Old 08-27-2006, 07:11 PM   #2
Car: 2005 STi
Fav Mod: Stage dos.
its not bad......................
609Audio is offline   Reply With Quote
Old 08-27-2006, 07:15 PM   #3
Nanned ®
Get catted, and yes it is easy to bolt on.
Old 08-27-2006, 07:17 PM   #4
i dont have to worry about any gaskets or anything...? or do they come with it..? also do i have to worry about any turbo lag if i have AP?
Old 08-27-2006, 08:23 PM   #5
Car: 06 WRX STI
Fav Mod: Invidia G200
All DPs should come with gaskets. A DP isn't hard to install yourself but make sure you use some pentrating oil on the nuts and bolts and make sure your engine has had proper time to cool. If you want to make the install super easy then buy an aftermarket heat shield or you'll have to modify the old one. Also one thing to think about is heat wrap or coating. I didn't heat wrap mine but it's a good option to prevent heat soak. Good luck...
boataholic is offline   Reply With Quote
Old 08-27-2006, 08:28 PM   #6
Car: 06 Subaru WRX
Fav Mod: winshield washer fluid
Send a message via AIM to trnkmnky
Most downpipes come with gasket that meets the exhaust, but you will probably need to get the gasket that goes between the bellmouth and the turbo. Also when you do it, if you take the intercooler off it makes it much easier. Oh and a Breaker Bar FTW
trnkmnky is offline   Reply With Quote
Old 08-28-2006, 12:32 AM   #7
ok thanks guys...one more stupid question....do i need to install a mid pipe to go stage 2? or can i go stage two with just the DP and stock exhaust..?
Old 08-28-2006, 04:56 AM   #8
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
You can go stage 2 with just the downpipe. Probably about 95% of the power gained from a TBE is gained from the downpipe. The midpipe and muffler (aka the catback) will only gain you a few horsepower at best. If you plan on staying at a "stage 2" level then you will be fine with just the DP. If you plan on going to a bigger turbo down the road then you'll need a full 3" TBE to realize the full gains.
Old 08-28-2006, 12:19 PM   #9
perfect... thanks
Old 08-28-2006, 01:51 PM   #10
Car: 05|WRB|STi
Fav Mod: Cobb Stage 2
Send a message via AIM to SoaReS
the only pain in the ass of the downpipe install is removing those 3487348735 bolts holding the heatshield in place.
SoaReS is offline   Reply With Quote
Old 08-28-2006, 03:15 PM   #11
lol haha i'll find out about it soon...
Old 08-28-2006, 03:47 PM   #12
Fav Mod: V-Limited lip/Kansai Diffuser
Trader Rating: (12)
Are there any step by step write ups floating around? I'd prefer to do the DP install myself, but I want to see exactly what I'm getting into.
DubyaSTi is offline   Reply With Quote
Old 08-28-2006, 03:56 PM   #13
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (77)
You getting into a sticky situation. Tideous, but not hard with some PB blaster and a nice breaker bar. That is if this is for the stock DP removal, which is tough because of that factory gorilla that tightens the living crap out of the nuts.
You can remove the intercooler, then proceed to remove the heatshield on the DP/Turbo. Once thats done all you got to do it the 5 nuts/bolts on the DP, and then two on the DP to catback portion. Its rather simple to understand, but can be a huge PITA.
Expect about 2-3 hours on a lift if its your first time.
Old 08-28-2006, 04:34 PM   #14
Muller Chevrolet
Fav Mod: a new 08 STi
^ what he said in additon to the bracket holding it with one bolt, which is located in front of the 02 sensor...can't forget that one too!
it's actually quite easy...the hardest part is not having the right tools...the bolts may be tight and usually are if it's been a while.
Old 08-28-2006, 04:36 PM   #15
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (77)
Dammit I just passed 5k posts
