Old 12-17-2006, 05:59 PM   #31
Car: 06 Yamaha R6 Raven
Fav Mod: NO car payments!!
Send a message via AIM to STIfreak7
Well other than the wonderful noise that it makes it has some benefits. It will completely cure the boost creep problem that occurs when you add a TBE and especially a catless TBE. An external waste gate (EWG) control and holds boost pressures much more acurate than a IWG. When looking at the switch to EWG in the long run I think it is a good thing to do if you are planning on swapping to an aftermarket bolton turbo. The EWG will offer a tuner much better control of boost with an different turbo.
I kinda looked at it from a long term perspective as I do plan on a new turbo down the road, and I wanted a fool-proof fix for boost creep.
STIfreak7 is offline   Reply With Quote
