Old 08-23-2006, 04:16 PM   #1
Default Help! Need to remove reverse lock-out ring
Help! I'm attempting to replace the reverse lock-out ring trim piece under the shift knob of my 2004 STi. There's a pin that passes through the center of the slider piece.
Has anyone ever removed this pin before? I can't seem to get it to budge. I'm concerned that it might not be a good idea to really wack it with a hammer and a punch. Any suggestions?
Tim
tkingsbury is offline   Reply With Quote
Old 08-23-2006, 04:21 PM   #2
Muller Chevrolet
Fav Mod: a new 08 STi
hammer and punch my friend, it works you just tap it out.
Old 08-23-2006, 05:42 PM   #3
Car: 2006 WRB STi
Send a message via AIM to Zabuza
On my '06 the punch size was 3/32.
Zabuza is offline   Reply With Quote
Old 08-23-2006, 05:48 PM   #4
Car: 2006 Subaru STI
Fav Mod: Still stock, until I get more money for them
Default here
undo the lever from the bottom , you need to get the reverse retainer ring tool and get the o ring so you have the lever free, and make somebody hold the lever for you while you use a 3/32 punch to get the pin out , be carefull and good luck
i_venegas76 is offline   Reply With Quote
Old 08-25-2006, 01:06 PM   #5
OK, I figured out that I could press the pin out with a C-clamp and a small metric bolt. Luckily, no need to wack it with a hammer.
So, now I have a different problem... The slider is off, but now to put the new one on it's place. Something odd has happened to the reverse lock-out. The slider wants to bounce upward to the reverse released position instead of staying down in the reverse lock-out position. Is the pin supposed to pass through/hold something in place. I must be missing something here. Is there a trick to re-assembling it?
Tim
Old 08-25-2006, 01:13 PM   #6
abracious
Fav Mod: Track time
you have to re-align the pin with the reverse lockout cable.
get under you car, fine the hinged reverse lockout deal on the transmission and lock it open. then you can get the pin placed correctly.
to figure out what i mean, search for a how-to on installing a short shifter.
