Old 08-20-2006, 01:23 PM   #1
Car: The Vroom-mobile
Fav Mod: JDM Gears
Default Turbo Inlet hose/pipe Install
Can anyone post up on how to do this? I heard im suppose to take off my intake manifold...
Anyhelp would be much appriciated!
Old 08-20-2006, 01:32 PM   #2
Car: 05 Aspen White STI
Fav Mod: Defi Gauges
Send a message via AIM to STI_Mike
Heres an install for an APS inlet it could help u out
http://www.airpowersystems.com.au/wr...ke/install.htm
STI_Mike is offline   Reply With Quote
Old 08-20-2006, 02:03 PM   #3
Fav Mod: JDM Gears
okay i ran into a problem, the stock turbo inlet seems to have 1 more valve then the perrin? the thing i circled is attached to it.
Old 08-20-2006, 02:13 PM   #4
i dont get wat ur saying it all looks the same...
Old 08-20-2006, 02:19 PM   #5
Car: 04
Fav Mod: teh hot wimmenz
when i installed mine, i just left it as is. i zip tied it to something so it wouldnt flap around. 20K miles later and its still perfectly fine.
dmacalot is offline   Reply With Quote
Old 08-20-2006, 02:20 PM   #6
Fav Mod: JDM Gears
see how the top of the stock one has 1 more hole compared to the perrin one?
Old 08-20-2006, 02:24 PM   #7
o ok i see now just do wat that other guy did .
Old 08-20-2006, 02:26 PM   #8
Fav Mod: JDM Gears
so that hose just sits there not connected to anything?
Old 08-20-2006, 03:36 PM   #9
Fav Mod: JDM Gears
no one?
Old 08-20-2006, 03:43 PM   #10
I'm Jim Halpert
Fav Mod: Ricer Flyby
i still have no clue what ur talking about but hopefully someone will help u
Old 08-21-2006, 07:21 AM   #11
Car: 04
yeah man, youre talkin about the hose with a white plastic piece thing on it, correct? if so, zip tie secure it and youll be all good..
Old 08-21-2006, 07:53 AM   #12
Car: 2004 Subaru WRX STi
Fav Mod: blasting you with the 44mm EWG!!!!!!
Send a message via AIM to ImprezivSTi04
no one?
that hose on the back of the stock inlet tube is the port the pcv sensor. in the instructions will tell you to join that hose together with the other pcv hose in the front of the inlet with a supplied plastic tee they send with the intake. the electrical connector that is back there is simply taken apart and the brass connector in the female end is put into the male end....the instructions explain it much better than me, trust me....its very simple and straightforward and you do not have to remove the intake with the perrin unit.
-corey
ImprezivSTi04 is offline   Reply With Quote
Old 08-21-2006, 08:33 PM   #13
Fav Mod: JDM Gears
thanks, i got it used so it didnt have any instructions or any other hardware =T
Old 08-22-2006, 07:27 PM   #14
Fav Mod: JDM Gears
okay so i found out i have to T it to something, but what?
