Old 08-09-2006, 03:27 PM   #1
Car: 06 Suabru STI 2006
Default How to adjust the STI 2006 Headlights
I saw a topic on this not too long ago but I can't find it. My headlights are too low and would like to adjust them.
tossty is offline   Reply With Quote
Old 08-09-2006, 03:31 PM   #2
Fav Mod: Not working in the Summers!
The 05's have a knob to the left of the steering wheel. The 06's do not have this?
RUGBY is offline   Reply With Quote
Old 08-09-2006, 03:33 PM   #3
Car: 06 OBP STI
Fav Mod: Invida G200 FTW!
Send a message via AIM to DARKSTI
They do, but even then sometimes it isnt good enough.
Old 08-09-2006, 03:36 PM   #4
That is right, is not good enough. If I can bring them up a little that should do it.
Old 08-09-2006, 03:43 PM   #5
Car: 06 Subaru WRX STI As
Fav Mod: Exhaust
in the back part of the headlight there is a screww and there u can put them higher or lower very easy
Luisillo subi is offline   Reply With Quote
Old 08-09-2006, 03:45 PM   #6
Car: 06 STI SGM
Fav Mod: seatbelts
Send a message via MSN to boost_happy
On your headlight assembly there's a spot where you can use a phillips screwdriver to adjust the height of the assembly. Make sure you have both of them equally adjusted. Park the car in front of a wall about ten feet away so you see them adjust. It looks like two gears next to each other. I put mine up and drive with the setting down a few notches, but when I'm alone on the highway I can raise them up without using brights, its a nice change. Good luck.
boost_happy is offline   Reply With Quote
Old 08-10-2006, 01:50 PM   #7
Luisillo, where are you from? PR
Old 11-26-2006, 09:54 AM   #8
Car: 06 AW STI
Fav Mod: Hardwired 8500
stoked its an easy fix. i noticed my first night run lat night they were a tad low for unlit mtn roads.
NorCALSpeed is offline   Reply With Quote
