Old 08-04-2006, 01:45 PM   #1
Default How To: Refill A/C Coolant
I am feeling that my A/C isn't cold anymore. I am wondering if anyone know how to refill the A/C coolant
- Charles
chaddeus is offline   Reply With Quote
Old 08-04-2006, 01:49 PM   #2
Car: 05 CGM WRX STi
Fav Mod: all
Just go buy a recharge kit from any car parts shop. Directions right on the can. Hook up to the low pressure side A/C lines (marked by an "L" on the cap, I believe its right next to the intercooler on the pass. side). Read the gauge on the can. Very quick and easy to do. Only takes about 10 min tops.
Edit:You should follow the instructions below and have it serviced professionally. I personally used the above method, but on an older beater car that I wasn't too worried about. On a newer vehicle you shouldn't need servicing yet, so that might be indicating another issue. I apologize for the confusion, I answered before thinking.
speedstyle is offline   Reply With Quote
Old 08-04-2006, 01:54 PM   #3
Car: 04 STi WRB
Fav Mod: CF hood
Default Refil A/C
This has to be done by a shop with a freon recovery machine
You have to vacuum down the system to remove moisture
You need to have someone check for the leak
It should not need freon
JC
judojohn is offline   Reply With Quote
Old 08-04-2006, 02:09 PM   #4
Car: 2006 Aspen White STi
Bring it to a shop! you need to clean out the A/C and you need a machine to do it. And it is ALOT of work!
cusco is offline   Reply With Quote
Old 08-04-2006, 02:12 PM   #5
Car: 06 Subaru WRX STI
Fav Mod: air freshener (mmm...squash)
could be the compressor going bad...
halfbr3d is offline   Reply With Quote
Old 08-04-2006, 02:30 PM   #6
The A/C is cold but not that cold so I was thiking of refilling it, in hoping that I get it cold again
-Charles
Old 08-04-2006, 04:46 PM   #7
Car: x2 05 WRX STi's
-Charles
I am a hvac tech and I can tell you the above people are correct take it to a shop to be checked. The low output could range from low refridgerant to compressor to a bad drier.
Just because the output is low has nothing to do with how much is in there. In fact if you overcharge the system (can be dangerous) it will have a low output also since the boiling off action is delayed past the evap instead of in it.
Sinister redlines is offline   Reply With Quote
Old 08-04-2006, 05:40 PM   #8
Muller Chevrolet
Fav Mod: a new 08 STi
bring it to dealer tell them to check the a/c
it's not hard, they use a special machine for it...
i had toyota recharge mine lol.
VSGTS14 is online now   Reply With Quote
