Old 08-04-2006, 01:00 PM   #1
Fav Mod: Soon to be FP RED with Axis Stage 3 Block
Default Turbo Install
Can anyone help me with a turbo install. I am going to a 20g so its not rotated or anything. Is it too hard and should I have it porfessionally installed, or is it fairly self explanatory. Thanks.
WRBSTI is offline   Reply With Quote
Old 08-04-2006, 01:25 PM   #2
Car: '05 Blue/Gold
Fav Mod: FPGreen & Track time
I'm interested in this as well. It is probably time consuming, however, my concern is "priming" oil to the turbo. I'm debating whether doing this myself, or just paying a tuner to do it.
FYI, I've never seen a writeup on this.
royalsti is offline   Reply With Quote
Old 08-04-2006, 01:35 PM   #3
Car: 2005 STi
Fav Mod: Stage dos.
Okay Here it goes:
1.Remove the center exhaust pipe
2. Seperate the turbo joint pipe from turbo charger
3. Disconnect the engine coolant hose which is connected to coolant filter tank
4. Loosen clamp that secures turbo to intake duct
5. Remove bolt which secures the bracket oil pipe to the turbo
6. Remove the oil pipe from turbo
7. Disconnect the engine coolant hose
8. Remove Turbo bracket
9. Disconnect the oil outlet hose from pipe
10. take out the turbo
and installation is the same thing just backwards.
put up your email and ill send you a PDF if you want.
609Audio is offline   Reply With Quote
Old 08-06-2006, 12:43 PM   #4
Car: '05 Blue/Gold
Originally Posted by jenzos
Okay Here it goes:
Thanks for the response.
Old 08-06-2006, 01:24 PM   #5
Muller Chevrolet
Fav Mod: a new 08 STi
uh just be sure to drain the oil out of the system and also the coolant or you're gonna have a party with that **** going all over.
Old 08-06-2006, 04:31 PM   #6
Car: 08 CBR1000RR
Fav Mod: None
No one has address priming the turbo. The best way to do this is to remove the passenger side door trim that goes up to the dash and disconnect two green connectors located under the cover. This will shut off the fuel pump. Then disconnect the #11 fuse. Then crank over the motor for about 30 seconds. This will prime the turbo.
Old 08-06-2006, 06:44 PM   #7
Muller Chevrolet
^trueee i did that, it helped.
Old 08-06-2006, 07:42 PM   #8
Car: cars, computers, shopping
Fav Mod: Engine ECU
Free Advise!
please take this to a tuner shop..they would know how to professionally install it..,,this guys here are just tellin' u the title of the job. "Remember what u pay for it"....its not a civic!
Private50 is offline   Reply With Quote
Old 08-06-2006, 09:21 PM   #9
Car: 05' STI
Fav Mod: Defi gauges, or TXS TBE or JDM sidemarkers...arg!
Arrow
Originally Posted by Private50
Free Advise!
I don't see how a tuner can do it any better.. Yes they may have done it 20+ times... but just because they have done it more times doesn't Necessarly mean it's better:
IE: We can pay someone to install a suspension and TBE... BUT if you are mechanicly inclined you can save yourself HUNDREDS of dollars buy doing it yourself..
I learned this lesson when I had my wrx and I paid the shop $600 to install, TBE, uppipe, complete suspension, sway bar, and strut bars, shifter bushings... From that point on I try to install EVERYTHING on the car or get someone that did it before to "watch" over me/help me...
That's why we have these forums, it's all about the group learning/experiences :-)
I'm not knocking what your saying just giving my opinion from past experience.
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 08-07-2006, 03:28 AM   #10
Car: 2005 STi
Fav Mod: Stage dos.
-Nigel
yeah i agree. for my first car I paid a local muffler shop 250$ to put on a Catback exhaust and header lol
Old 08-07-2006, 03:51 AM   #11
Car: '05 Blue/Gold
Free Advise!
I appreciate your input. Guys, working on a car is not rocket science. I find it fun and challenging to do these things myself. I think this is why alot of us are members here. Things will never go in as you plan them to. However, working through these installs help us to think outside the box. This is something we can use everyday in life too. Therefore, working on my car makes me smarter. Lol.
Old 08-07-2006, 08:06 AM   #12
Muller Chevrolet
i never ever tackled such an install before and tore down/rebuilt my entire turbo project..by myself.
any problems? no.
Old 08-07-2006, 08:29 AM   #13
Fav Mod: HKS Kansai Diffuser
Send a message via AIM to TIMELESS
Pics for this would be awesome...I would but I'm too busy with work
TIMELESS is offline   Reply With Quote
Old 08-07-2006, 12:15 PM   #14
Fav Mod: Voltex!
dont lie ken,
you dont work
STIBLITZ is offline   Reply With Quote
Old 08-08-2006, 01:21 PM   #15
FYI i work it 24/7 lol
