Old 07-31-2006, 02:45 PM   #1
Default How to remove 06 tail lights?
How do you remove 06 STI tail lights? It would be helped if you can get step by step info and pictures.
Thanks
ahh01010 is offline   Reply With Quote
Old 07-31-2006, 03:15 PM   #2
Car: 06 STI
Fav Mod: Prodrive oval tip
it's probably pretty easy.. just pull the carpet back and see all the screws. take the screws off and the bulbs out and it should come off...
Old 07-31-2006, 03:24 PM   #3
Do I need to remove the bumper? or just the screw behind the carpet?
Old 07-31-2006, 03:46 PM   #4
Car: Blue Slate 08 G37S
Fav Mod: None
Send a message via AIM to VtecSTI Send a message via MSN to VtecSTI Send a message via Yahoo to VtecSTI
just take the bolts off that hold the tail lights in. It's easy man
VtecSTI is offline   Reply With Quote
Old 07-31-2006, 03:50 PM   #5
Car: '06 WRB/Silver STI
Fav Mod: Kartboy Gear
Pull the carpet back and there are like 4 bolts that you have to undo. Undo about two plugs and your done.
krazyk1371 is offline   Reply With Quote
