Old 07-27-2006, 03:10 PM   #1
Car: 06 white w/gold STi
Fav Mod: gt40r
Send a message via AIM to Blaiser
Default Up Pipe Cant Get Out Help...urgent
i cant get the stock up pipe out, and i am in the middle of installing my aps headers, anyyyyone help me? how do i get the stock up pipe out?!?!?!
Blaiser is offline   Reply With Quote
Old 07-27-2006, 04:59 PM   #2
Car: White 06 STi
Fav Mod: Forged Bypass
Send a message via AIM to ilami01 Send a message via Yahoo to ilami01
dont be scared! its easy once you get started, let the car cool down!, you have alot of heat shields to take off and i think 1 o2 senser, might be two.
ilami01 is offline   Reply With Quote
Old 07-27-2006, 05:13 PM   #3
Car: White 06 STi
lttle tip, the boltz on the headers connecting the actual headers together from one side to the other (not to the blobk) are steel and tend to be a pain....to get off so some rust off really helpz!
Old 07-27-2006, 05:24 PM   #4
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
1. buy PB Blaster.
2. get car in the air and ready to install the night before.
3. drown the bolts in PB Blaster. use the entire can.
4. install headers
5. profit!
i don't know a lot about the install yet since i still have to install my headers (MadDad headers + uppipe) but i did help out on an uppipe install on a WRX and it should be similiar. fortunately since we don't have an EGT probe in the uppipe it's a lot easier to remove. most people have told me that once you unbolt it from the turbo is pretty much falls out.
basic steps:
1. remove downpipe
2. remove heatshields around stock exhaust manifold
3. remove bolts connecting uppipe to the exhaust manifold and the O2 bung
4. remove bolts holding exhaust manifold
5. remove uppipe
6. reverse to reinstall the new APS header.
or um check the APS website next time for install instructions... :P
http://www.airpowersystems.com.au/us...rs/install.htm
i shoulda looked before i wrote up all the stuff above.
Old 07-27-2006, 05:35 PM   #5
Car: 2005 White/Gold STi
Fav Mod: TD06-20G/Tein Flex coilovers
Originally Posted by kts262
1. buy PB Blaster.
4. install headers
5. profit!
basic steps:
1. remove downpipe
5. remove uppipe
You forgot 1 step..
7. Make sound clip
pt518sti is offline   Reply With Quote
Old 07-27-2006, 06:00 PM   #6
Fav Mod: gt40r
I CANT GET THE HEAT SHIELD AROUND THE 02 SENSOR OFFFF! ogwjehoigrhj.
anyone know how i can do this? its making me mad.
Old 07-27-2006, 06:22 PM   #7
Car: 05 LGT w/ AVO420
Fav Mod: AVO420 Turbo
cut it off with a dremel if it comes to that.
LRM1981 is offline   Reply With Quote
Old 07-27-2006, 06:22 PM   #8
HowTo Contributor
Fav Mod: stock FTL?
1. Remove the O2 sensor?
2. ????
3. Profit?
Old 07-27-2006, 07:14 PM   #9
Fav Mod: gt40r
ok. heat sheild is off (i love my dremel) but now i need to remove the bolt by the 02 sensor but the sensor is blocking it kinda, should i cant get to the o2 sensor while the manifold is on, how do i surpass this obstacle.
Old 07-27-2006, 10:34 PM   #10
Car: 06 STi
Fav Mod: GST Tune
Well I got my up pipe to header bolts off with just 2 14mm wrenches and a lot of pb blaster. My gruppe-s header didn't want to fit while my subframe was in place, so I took my subframe off(easy to do, just a few 17mm bolts and a few 14mm bolts) and that makes it a lot easier. With the subframe off you can take off the o2 sensor(I used a 22mm wrench) then take off the 14mm bolts or vice versa.
xtremeyolks is offline   Reply With Quote
Old 07-28-2006, 07:10 AM   #11
How YOU Doin?
Car: 2006 Audi S4
Fav Mod: OMGHI2U!
Send a message via AIM to jsh139
Scoobymods has a good write-up on it.
http://www.scoobymods.com/forums/sho...ghlight=uppipe
jsh139 is offline   Reply With Quote
