Old 07-21-2006, 04:59 PM   #1
Default Where do i put jack stands on my car?
I have to do my SS brake lines tomorrow. i would like to know the 4 points on the car i can put my jack stands along with the place i can put the floor jack on the body so i place the 4 jack stands. does anyone have a picture could explain where i put them?
2005STI is offline   Reply With Quote
Old 07-21-2006, 05:09 PM   #2
Car: 2006 STI OBP
Fav Mod: Kartboy SS
Send a message via AIM to Doctor Subie
you put them underneath the car...
j/k, couldn't resist...
I put them right to the inside of the jacking points on the sides of the car. I usually jack the car up from either the rear diff. or the front diff or transmission crossmember. Sorry, no pictures...
Doctor Subie is offline   Reply With Quote
Old 07-22-2006, 06:14 AM   #3
Fav Mod: MSPT tune - Thanks Dave!
I use the jacking points. I jack the car up one side at a time, putting the jack under a beefy looking part of the subframe. I go about halfway on one side, then all the way on the other side, then back to the first side to level it out. Takes a while, but so far so good.
HighSpeedLowDrag is offline   Reply With Quote
Old 07-22-2006, 07:21 AM   #4
Car: 05 Black on Black
I do the same as DR. SUBIE does. I drive up on ramps, then I jack up the rear from the differential and put the jack stands on the rear jacking points. Then I jack the front up from the crossmember-looking thing under the engine, and put jack stands on the front jacking points. Works like a charm.
Just make sure while your jacking the back up that the car isn't about to roll off the ramps..make sure your on a nice flat surface. My driveway is alittle bit of an incline, so I try to get someone to sit in the car with they're foot on the brake.
DoubleURX is offline   Reply With Quote
Old 07-22-2006, 07:32 PM   #5
Car: 06 STI
Fav Mod: Prodrive oval tip
for the front.. i put my jack stands on the subframe thing... for the rear, i dunno. I still don't feel comfortable jacking up the car by the differential
Old 07-22-2006, 10:15 PM   #6
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
Check your owner's manual. There are 4 spots along the side skirts that are ridged and are where to jack the car up using the crappy stock sissor jack or another jack. They are just behind the front wheels/just before the rear wheels. A diagram of these spots and other safe jacking points are in the owner's manual.
The rear diff can be used to jack the entire back up and the cross member on the front can be used to lift the the entire front of the car up, if you can get a jack under there. When I was still on my stock suspension there was no hope of getting a jack under there, now it's even worse since I've lowered it and installed the V-Limited lip. I have small ramps I drive up which give me just enough clearance to get a jack under the front of the car.
Old 07-22-2006, 11:18 PM   #7
Fav Mod: Tial 44mm EWG
if someone could get pics of where on the differential in the front and back to jack it up id appreciate it.
Old 07-25-2006, 12:55 AM   #8
Car: 06 Subaru WRX STi
Not sure if this will help you or not
http://www.scoobymods.com/forums/sho...ht=jack+points
Old 07-25-2006, 10:56 AM   #9
Car: 06 STi WRB
Fav Mod: Snow Tires
I like to put the Jack Stands under the front frame rails. And on the rear under the sub frame mounts.
ianparcher is offline   Reply With Quote
Old 08-09-2006, 10:40 AM   #10
Car: 08 Silverado 2500HD
halfelite thank you so much. That is what I was looking for!
1FSTSTI is offline   Reply With Quote
