Old 07-21-2006, 01:01 PM   #1
Default Noob Help. Maddad boost wiring
I have a single maddad boost gauge mounted on my apillar. the vacume line is hooked up but i do not know were to wire the power to and were to put the ground. pictures would be very help full.
BlowDrp is offline   Reply With Quote
Old 07-21-2006, 01:03 PM   #2
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (77)
you can wire them anywhere.
Ground can go to any ground wire or ground point.
If you want an easy power, tap right into the cig. lighter line.
Old 07-21-2006, 01:23 PM   #3
will that still work with the dimming feature? which wire is power in the cig lighter?
