Old 07-18-2006, 06:35 AM   #1
Send a message via AIM to the_brad
Default Stock Bypass Valve Reinstall??
Ok so I bought an 04 STI about 3 months ago and it had a Greddy Type RS BOV on it which makes it run like <explitive deleted> so I finally found a stock BPV on ebay. Now that I have it, I'm not quite sure how to put it on. I see the stock vaccum tubing is still in place, but the air return tube that mounts underneath it has some sort of cap on it. I haven't had time to really look at the setup and this is just what I've observed from a quick glance. Any tips/instructions on how to strap my BPV on??
Thanks
the_brad is offline   Reply With Quote
Old 07-18-2006, 06:38 AM   #2
Car: 05 Black on Black
uncap your stock return hose. That hose connects to the 'exhaust' side of the BPV. Its a very straight-forward swap, and shouldn't take more than 30 minutes even if you've never done it before.
DoubleURX is offline   Reply With Quote
Old 07-18-2006, 07:15 AM   #3
Car: 05 Subaru WRX STI CG
The Greddy RS bov may come with its own metal tubing for a recirculation line (I believe its the greddy that does this). If this is the case, you may have to either go buy hosing to fit the tubing to your recirculation valve or re-purchase the stock recirculation line (rubber) or find one from an aftermarket company as I believe there are a couple companies that sell this (samco, perrin, etc). Hope this helps!!
Edit: **Image borrowed from JSCSpeed
That metal tube is what I am talkin about needing to be replaced if its on there (or you could possibly rig up some hosing to fit the stock recirc valve).
Robert~
Old 07-18-2006, 07:25 AM   #4
No, from looking at pics of other sti's bpv it looks like i still have the stock tubing and its certainly not the metal tubing. I get the bpv today and I can test to see if the tubing fits, if not I'll probably head over to the suby dealership and see what they can get me.
Thanks for the help guys
Old 07-18-2006, 07:31 AM   #5
Cool, if you have the factory recirculation line, then its as simple as popping out the cap on the recirculation line, undoing a vacuum line, and 2 bolts holding the bov in. It should make more sense when you get the item in let us know how it goes!
Robert~
Old 07-19-2006, 11:38 AM   #6
Everything went smoothly, but I had to dismount the intercooler and scoot it over a little to get the BPV in the exhaust hose. Other than that everything was super easy.
The car runs ssoooooo much better now; the difference in the smoothness of the shifts and in the idle is incredible.
Thanks guys.
Old 07-19-2006, 12:25 PM   #7
Excellent glad it all went so well
Robert~
Old 07-25-2006, 01:37 PM   #8
Guys, sorry for hijacking this thread, but I am trying to do the same thing. How can I know if I have the stock tubing. Right now I have a FORGE BOV and would like to return it to stock
mmasse is offline   Reply With Quote
Old 07-27-2006, 11:15 PM   #9
Car: 2008 A4 6MT LOADED
Fav Mod: I miss my Subaru...
Thanks guys.
shift intercooler permanently?? lol just pull the hose to where u need it..
check under and left of the BOV.. there should be a rubber hose about an inch and a half thick.. and it should be plugged up by some kind of stopper.. just remove the clamp, take the stopper out.. and plug and play
FujiApples is offline   Reply With Quote
