Old 07-06-2006, 07:00 AM   #1
Car: 04 STI
Fav Mod: Koni shocks
Default TBE install any tips?
Looking to install my APS TBE, any tips on getting the stocker out? Thanks!
kinger is offline   Reply With Quote
Old 07-06-2006, 07:23 AM   #2
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
pb blaster, a breaker bar, gloves (i use the mechanix ones. i've seen people not use gloves and have their hand slip off a wrench and end up getting stitches), patience. the bolts that connect the downpipe to the turbo are the hardest, and in particular there are 3 (or 2) that are hard to get to. i would suggest finding instructions online that show you where all the bolts are to make it easier.
Old 07-06-2006, 07:25 AM   #3
Car: Waiting for the STI
Fav Mod: Driving My Car
MODS you might want to move this to the HOW/TO install section
_________________
Tips, make sure the car is cold and remove the intercooler. People say it is not necessary but it is way easier to work around if it is off. PB blaster the bolts of the heat shield, remove the heeat shield, once you remove it yo uwill see the turbo and the begining of the DP. PB blast the 5 bolts that surroung the turbo and the DP.
Get under the car and PB blaster the rest of the sections.
You will need a 14mm to get the bolts of the turbo, and a 17mm for the heat shield of the stock DP that bolts to the engine. The best way to get that one is with a long extension and a swivel at the end.
wratchet wrenches help a lot here, so if you do not have any its time to invest.
This should help you out
http://www.scoobymods.com/forums/showthread.php?t=4026
sebtarta is offline   Reply With Quote
Old 07-06-2006, 07:27 AM   #4
Nanned ®
To add to Jakes list, extra bolts ( just in case you break one ).
Old 07-06-2006, 07:40 AM   #5
Car: 05 WRB/Gold
good call seb, moved.
Old 07-06-2006, 07:46 AM   #6
Car: 2004 WRB STi
Fav Mod: Earplugs.
Send a message via AIM to ZenBoy
Actually, you might want to add an extra car to the list too, for the inevitable "parts run".
I got a new gasket for the turbo/DP joint, too. Make sure you have poly exhaust hangers, since presumably you're working with a larger exhaust than the stock one and there isn't a lot of room to work with. You might need to snip the heat shield above the muffler if it's a good-sized muffler.
For mine, it was easier to remove the cat-back exhaust and the DP separately, because I didn't have a lift to work with.
Last but not least, I'm a stickler for torquing bolts properly (learned that one the hard way over many years). A couple of the DP/turbo bolts are difficult to get at without removal of the intercooler.
ZenBoy is offline   Reply With Quote
Old 07-06-2006, 07:59 AM   #7
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
everything evil said is great.
1. get the car to where you are going to be working on it and get it in the air the night before.
2. remove the intercooler and remove the heat shield
3. spray all the bolts with PB Blaster and let it sit over night. PB Blaster is your friend and it's cheap. Drown the bolts with it.
4. make sure you have all of the gaskets, new nuts and bolts, and tools you'll need.
5. also make sure you have a dremel/cutting tool if you're hacking up the stock heatshield or have a replacement one (Cusco, Cobb, etc) ready. i have the Cusco one and it's great.
Here's a pretty good guide w/ lots of pictures I looked at before I did my install: http://www.clubwrx.net/forums/showthread.php?t=39284
Also a link to the write up I did for removing the intercooler: http://iwsti.com/forums/showthread.php?t=52452
Old 07-06-2006, 01:22 PM   #8
Car: 05 LGT w/ AVO420
Fav Mod: AVO420 Turbo
Carefull not to break the downpipe bolts like i did...make sure you got all the right tools.
LRM1981 is offline   Reply With Quote
Old 07-06-2006, 02:26 PM   #9
Car: 05 STI
Send a message via AIM to RedlineSTI
what kts262 said.. spray the bolts good. you don't want them breaking on you like they did with me. it was a PITA to get it out.
RedlineSTI is offline   Reply With Quote
Old 07-06-2006, 03:21 PM   #10
Car: The Vroom-mobile
Fav Mod: JDM Gears
Im surprised no one has sead this, get a friend to help you. Doing it alone sucks, i did mine alone and MAN did it suck.
Old 07-06-2006, 03:56 PM   #11
Fav Mod: Leather Interior w/ Rear Pass thru
def two jack stands, exhaust hangers and also lithuim grease!
izzodesh is offline   Reply With Quote
Old 07-06-2006, 03:56 PM   #12
Bronze SEMA 2007 Sponsor
....logical.... You would think.
STi_4_Daddy is offline   Reply With Quote
Old 07-07-2006, 05:04 PM   #13
Car: 06 Subaru WRX STi
Send a message via AIM to JimmyD17
amen to the PB Blaster. and definetly dont do it alone. its a lot easier and more fun with a friend
JimmyD17 is offline   Reply With Quote
Old 07-08-2006, 07:58 AM   #14
Car: 04 WR Blue STi
Fav Mod: HKS Hi-Power
Send a message via AIM to BluePearl04
If you're lucky enough, power tools
BluePearl04 is offline   Reply With Quote
Old 07-11-2006, 07:12 PM   #15
Car: 05 WRX STi
Fav Mod: More Power
I used 2 jacks, a jack stand, PB Blaster, lots of tools, my brother and a few beers........a bout 2 hours later my car sounded sweeeet!!! It's not hard to do, but the bolts on the DP are tough to get off, soak them over night like everyone says and it will be much easier.
alwaysbikn is offline   Reply With Quote
