Old 07-20-2006, 11:16 PM   #16
Car: '05
Fav Mod: AP
i had the same problem with fluctuating idle after my install, but not to the point where the car felt like it was going to stall. i recently reset the ecu & flashed to stage 2 93 map. the weird idle is not as noticable.
Originally Posted by i_venegas76
I just installed the Injen CAI in my 06 Last nigth and I had a vacum leak bigtime on the hose that goes closer to the engine, I fixed after dave told me to check the hoses and the clamps .Well Today I still have this attemting to stall anytime on the car and a very low iddle that scares me
I have the Cobb AP and doin stage 1 93 on the gas, do I have to update a new map on the real time maps B/C of this CAI?
dannyblaze_07 is offline   Reply With Quote
Old 07-21-2006, 10:21 AM   #17
GZA
Super Moderator
Car: 2005 STi
Send a message via AIM to GZA
I just installed this intake last weekend and had idle problem at first, I think it may have been that I put my MAF on backwards originally. (See thread I started for more info) Hardest part of the install, for me, was pulling out the old snorkus and fitting in the 2nd part of the piping for the CAI. The snorkus has a bolt deep into the fender, which was somewhat hard to reach. To install I just took off the wheel and pulled back the fender liner, which tore a little
GZA is offline   Reply With Quote
Old 07-23-2006, 11:37 PM   #18
Car: 2008 A4 6MT LOADED
Fav Mod: I miss my Subaru...
Originally Posted by Endless_STi
Sorry for going off topic, but would any of you be willing to record a short clip of the injen cai? I want to hear how it sounds compare to the K&N typhoon or APS CAI. Thanks!
i have both injen and k&n... none of which are better than the stock airbox.. ok.. anyways.. they sound exactly the same.. and they will cause your acceleration to flutter...
the intake will not cause your car to throw a cel.. if it does.. u screwed up insalling it
there is no freakin reason to get the injen intake unless u have a highly modded drag machine.. even in that case.. its very rare to be using an injen... uh.. u will get a lot better throttle respons and accel with stock airbox if your running the stock turbo...
hmm.. yea i was stupid enough to try on an injen.. the k&n is quite good.. close to stock.. but i would say dont bother.. take off the snorkel and u still get the sound.. just slightly quieter.. plus lowers your chance of bad a/f mixure.. especially if u have an aftermarket exhaust...
ok have fun
FujiApples is offline   Reply With Quote
