Old 06-23-2006, 09:10 AM   #1
Car: 05 CGM WRX STi
Fav Mod: all
Default Downpipe/Exhaust torque specs
Could anyone tell me the torque specs on the Downpipe and Exhaust?
I tried to do a search and came up empty handed. I also looked in the 04' STi service manual posted in the donating members section but I believe the exhaust section has been corrupted because it doesn't seem to work. So if anyone has these torque specs, I would greatly appreciate them.
speedstyle is offline   Reply With Quote
Old 06-23-2006, 12:22 PM   #2
Car: 05 CGM WRX STi
Fav Mod: all
nobody here used the torque specs when installing thier downpipes?
Old 06-23-2006, 01:11 PM   #3
If in doubt, flat out
Trader Rating: (23)
-26 ft/lbs for the turbo to downpipe
-13ft/lbs for the downpipe to center pipe if its a spring joint (has springs on the bolts).
-the other joint 35.4 ft/lbs.
Side note: my aps exhaust didn't have a spring joint so tightened all the joints (except turbo to downpipe) to 35.4ft/lbs.
Old 06-23-2006, 02:18 PM   #4
Car: 05 CGM WRX STi
Fav Mod: all
Thank you very much
Old 06-24-2006, 06:41 AM   #5
Muller Chevrolet
Fav Mod: a new 08 STi
the dp to turbo...just make as tight as you can without breaking anything.
mine came loose like three times now because they need to be really tight.
